Question about Maxi-Cosi Maxi Cosi Rodi XR 'Phantom' Brand Booster Car Seat
I cant seem to put the hooks into the side of the backrest lock into the arms of the seat base
  • 8,197 Answers
Here is the manual for the Rodi XR. It will tell you how to put the hooks in.
http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/4358-4583rodiXR.pdf
Posted on Dec 13, 2009
HOW TO ASSEMBLE WEIGHT BENCH ?
Lay out all the pieces and check the instructions to make sure everything has been included with your weight bench. Attach the cross brace to the left upright beam and repeat the process for the right upright beam. Tighten them together with carriage bolts and set the backrest adjustment bar onto a slot on the upright beams.
Connect the main seat support beam to the cross brace with two carriage bolts, two washers, and two nuts. Do not completely tighten the nuts in place. Attach the main support beam to the front post with Allen bolts and washers. Connect the diagonal support beam to the front post in the same manner. Attach the other end of the diagonal support to the main seat support beam.
Place the arm curl stand in the front post and secure it in place with a lock knob. Tighten it down completely. Connect the leg developer post to the bracket on the front side of the front post. Attach the arm curl handle to the open bracket on the leg developer with an L-shaped lock pin.
71hekan4jtl._sl1500_-qw1ux3sfzoyydmyeq2qu2kbl-2-0.jpg Attach the bracket supports to both ends of the pivot arm of the support beam and lay the other ends on the backrest adjustment Pull up bar. Connect the backrest board to the supports with four hex bolts. Attach the seat pad with four hex bolts onto the main seat support.
Secure the preacher pad arm to the curl stand with two Allen bolts. Put two foam tubes into the leg developer halfway through the holes and attach the four foam rolls onto the ends of the tubes.
May 28, 2018 | Bench Exercise & Fitness
Remove rear seat
Rear seat cushion-fold forwards,release plastic clip from hinge,remove wiring multiplug if applicable.Lift out cushion.(40% backrest)Tilt forward approx 20degrees,use a screwdriver to release catch retainer on outer pivot pin.lift backrest and withdraw from inner pivot pin.Lift the backrest from inside vehicle.(will only lift out if backrest is tilted forward 20degrees from verticle. 60% section can then be removed on saloons by releasing the lock with a finger and pulling from the anchor pins.On estates unscrew centre seat belt lower mounting and unscrew hinge pin from centre support. unhook upholstery clip and lift backrest from lefthand side mounting.slide backrest towards the door to release centre pinlug and withdraw backrest from inside the vehicle. Refit in reverse order.
May 22, 2015 | 1999 Saab 9-5
Seat adjustment
Most of the seat backrest adjustments I have seen are via a strap attached to each side of the backrest uprights with a quick connect buckle and/or a slide through buckle like on a backpack, photo attached. maybe you could make something like this out of a old school bag strap. good luck. be safe :-)
Feb 07, 2014 | Peg Perego Milano XL Stroller
How to remove the rear bench seat from a 1997 Geo Metro?
at the base of the seat down were the floor meets the seat check to see if there are 2 bolts one on either side of the seat about in the area of wear you would sit(not in the center or outer edge of seat)by the floor.if so remove the bolts and lift the seat up and out.if not the in the same area were the bolts would be push down on the forward part of seat and lift outwards away from the rear of the car a bit and the seat lock should release the seat and lift up and remove.the backrest of the seat should be bolted to the the steel framing of the car then lift the seat back straight up and off the hooks.
Apr 10, 2011 | 1997 Geo Metro
How do you change the oil in the rear axile of a 4wheel drive 2007 tahoe
Hi, the axle has a drain plug at the bottom, removing this plug allows all old fluid to empty, put the plug back in, and tighten. fill back up with 2-3 qts of 75 synthetic weigt oil. Good luck...Coop
Dec 12, 2010 | 2007 Chevrolet Tahoe
I recently put some things in my trunk and now the lock won't turn. And some genius decided that the back seats should not fold down. Am I screwed?
i am talking from memory,and i may be wrong........but
look under the front base of the rear seats,you should find 2x screws,undo these and lift the seat squab up and frontwards out the flat possition then you will be able to find the screws that hold the backrest in possition and remove....
Sep 13, 2010 | 1998 Toyota Corolla
How to remove the rear seat
Rear seats are fastened in many different ways. On most cars, the base part of the seat is held in place by a metal snap going into a hole. To remove, pull on the front of the seat. Some cars have a metal or plastic tab that has to be pulled, pushed, or moved to the side, while pulling on the front of the seat. Other cars, mainly German, use bolts or screws in the front to hold the base of the seat. Many American car seats (GM) have a hook that fits into a metal brace. To remove the bottom part of the seat push hard towards the back and then up. Most Hondas use a bolt (10MM) on the back part of the seat between the bottom part of the seat and the back support (towards the middle) that has to be removed. Then the seat can be pulled up from the back. Before you pull on a seat, try to analyze what is holding it. Most seats do not need a lot of force to be removed, they all have a trick.
The back support on the rear seat is a bit more standard in the way it is fastened. At the top, there are 2, 3 or 4 pieces of metal that go into a hole. There are 2 or more bolts that hold the backrest at the bottom. Once you have removed the bottom part of the seat, take the screws or bolts out, and slide the back rest up and out. On a few cars you have to remove the rear deck and other side panels out first. If you can't figure it out, remove the panels in the other side of the backrest (trunk) and examine carefully how the seat is fastened.
Hope this helps, good luck!
Jul 27, 2010 | 2001 Kia Sephia
Just bout a used '02 vmax. I put stock seat back on. Now the release for the gas tank is not working. Any takers on how to get it off to look at what is going on?
From Orig Owners Manual on how-to :
Read carefully and hope it helps.
Fuel tank cap
To remove the fuel tank cap
1. Push the levers on the left and
right side of the rider seat backrest
as shown and slide the rider seat
backrest forward.
2. Insert the key into the lock, and
then turn it 1/4 turn clockwise. The
lock will be released and the fuel
tank cap can be opened
To install the fuel tank cap
1. Insert the fuel tank cap into the
tank opening with the key inserted
in the lock.
2. Turn the key counterclockwise,
and then remove it.
3. Slide the rider seat backrest rearward
and push it down.
NOTE: @
The fuel tank cap cannot be installed
unless the key is in the lock. In addition,
the key cannot be removed if the cap is
not properly installed and locked
To install the rider seat
1. Insert the projection on the front of
the rider seat into the seat holder
as shown.
2. Place the rider seat in the original
position, and then tighten the bolts
and screws.
NOTE: @
Make sure that the seat is properly secured
before riding.
3. Return the rider seat backrest to
the original position
Mar 22, 2010 | 2002 Yamaha V-Max
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
How do you make the britax monarch a backless booster?
While holding onto the base, push the backrest all the way backward. This will take some force. Once the backrest is flat, you can slide the axel off. Note that it only slides off one way - toward the open end.
Oct 06, 2008 | Britax Monarch - Red Racer Booster Car...
Maxi-Cosi Maxi Cosi Rodi XR 'Phantom' Brand Booster Car Seat Logo
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
