Question about HP Officejet Pro L7680 All-In-One Printer
HP7680 Blk/Yellow printer head problem
Can't make the sign go away. Pulled the head and cleaned it manually with a soft cloth & used a swab to clean the contact area down inside the printer.
All this came about when the printer bar got stuck. I have been able to solve the printer bar problem before by manually moving it over to the right side. However, this printer head problem is something new.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 46 Answers
Try the above solution doesn't work you will need to replace your black / yellow printhead.
Reply to this thread if after replacing your printhead doesn't solve your problem.
Posted on Sep 12, 2012
    Guru:
  • 1,738 Answers
Try unpluging the printer for about fifteen minutes or so.
Posted on Dec 12, 2009
Want to know how to manually clean printer head
You can, but the objective is to soften the dried ink, that blocks the tiny ports.
In my estimate the alcohol will dry too fast.
Printer UNPLUGGED from power, and you may wish to don some gloves.
(Dishwashing gloves?)
The ink likes to go everywhere.
Remove the ink cartridge/s.
As you can see, the copper metal strip area, on the ink cartridge; has TINY little holes in it.
I use a clean soft static free cloth, and soak the end I'm going to use; in as hot a water as I can stand.
Then reduce the water in the cloth, (Squeeze), so the wet area, is just damp.
Wipe across the copper area, and it's tiny ports.
Wipe across once, then find a clean area on the cloth; and do so again.
Keep wiping until cloth comes away clean.
I also do the same on the metal area, of the printer; that the metal area of the ink cartridge touches.
There are matching tiny port holes there also.
Keep wiping, adjusting for a clean area after each wipe, until cloth comes away clean.
I then follow with a can of compressed air for computers, and make sure the areas are DRY.
Q-tips, and Isopropyl alcohol, (Rubbing alcohol), sounds more intelligent, to me.
However the amount used may fill up a small bag, IMHO.
I know what you're thinking. Is this guy N-uts?
Water and Electricity do not mix!
(Actually they do. Water is an excellent conductor)
I watch to make sure there are no drips from the cloth, when using it. Have a dry cloth handy for the other hand, if they do.
I also make SURE the areas are DRY, before reinstalling ink cartridges.
I find VERY warm water helps break down the dried ink.
Always willing to learn something new, however.
For additional questions please post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | E-Machines eMachines Desktop PC
Tip
How to clean electronic equipment
<li>Unplug any cables or power cords from the electronic equipment before working on them. Remove any component cables leading to other devices.<br /> </li> <li> 2 Wipe down the electronic equipment with a soft damp cloth starting at the top of the device and working downwards. Wipe away any accumulated dust, lint or dander.<br /> </li> <li> 3 Use a small amount of isopropyl alcohol on a soft cloth to remove fingerprints from any CDs or DVDs. Work from the center of the media outwards. Do not rub too hard or in a circular motion.<br /> </li> <li> 4 Clean a LCD television or <a href="http://www.ehow.com/computers/">computer</a> monitor screen by wiping a damp cloth gently across the screen once all power is disconnected. Wipe down the ventilation area to remove any dust. Clean the base with the same cloth.<br /> </li> <li> 5 Open a computer case by removing the screws that hold the side in place. Blow dust and debris from the interior with a can of compressed air. Start at the power supply and blow through the rear ventilation fan. Continue to dust the motherboard, component slots and case.<br /> </li> <li> 6 Insert a compact disc cleaning disc into CD and DVD players to better clean up these electronic devices from the inside. This cleans the interior lenses, removing dust accumulation that can lead to early device failure.<br /> </li> <li> 7 Rub down an MP3 player with a soft cloth and a small amount of ammonia-free glass cleaner. Use a cotton swab to get into crevices and hard to reach areas that trap debris.<br /></li>
on Dec 16, 2010 | Audio Players & Recorders
HP 4650dn printer, two problems: 1) color streaks on the print out 2) black color a bit gray, and turn a a bit white when superimposed on other colors (except yellow)
Please use the Print Quality Troubleshooting Tool for your printer's model at the following link:
http://h10039.www1.hp.com/cpso-support-new/pq/4650/home.html
This will take you through a step-by-step process to diagnose the cause of the problems you have & correct them.
Feel free to let me know if you need any further assistance.
Dec 17, 2010 | HP LaserJet 4650 Color Printer
THIS IS FOR: "glenncuneo" Epson PictureMate
Hi. I provided you a manual for your printer. Please click here.
Nov 05, 2010 | Office Equipment & Supplies
My printer does not work at all. when i turn it on there is an E in the copies area and the check print cartridge light is blinking but im pretty sure there is enough ink.
Try cleaning the printer head contact by using video head cleaner spray. Spray on both contact on the print cartridge and the print head inside the printer. And wipe off the dirt with clean soft cloth.<br /> <br /> First you need to power up the printer and open the front cover.<br /> The printer head will move into center and then you can pull out the power cord. Note that never clean the contact when power is on. Otherwise it may be permanent damage.<!-- from fixya rte -->
Aug 08, 2010 | HP PSC 1315 All-In-One InkJet Printer
I have a bunch of hp 1300 printers. new q2613x
Perform the steps given below to clean the cartridges manually
=== Manually clean the ink cartridge and the contacts on the printer ===
1. Turn on the power to the unit and raise the cartridge access cover.
The cartridges will move towards the center.
2. After the carriage (the cartridge holder) stops, unplug the power
cord from the back of the unit. This will keep the cartridges from
moving back to the capping station.
3. Remove the cartridge(s) from the carriage.
4. Using a soft, clean, lint-free cloth or a cotton swab lightly
moistened with distilled, filtered, or bottled water gently clean
the face, edges and the electrical contacts. (Change to a clean
cotton swab as needed).
CAUTION: Be careful not to touch the ink nozzles on the bottom of
the print.
5. Inside the All-in-One, clean the contacts in the print carriage
with a slightly dampened soft, clean, lint-free cloth. Allow the
electrical contacts to dry completely.
now check if the issue still persists.
May 20, 2010 | HP Printer Cartridges (Complete List): ,...
Maintenance of Fingerprint scanners
How to Clean the U.are.U Fingerprint Reader
  • Apply the sticky side of a piece of adhesive cellophane tape to the window, and then peel it away, OR
  • Gently dab the fingerprint reader window with a cloth that has been dampened with a mild ammonia-based glass cleaner, such as Windex. (Do not use paper!)
Feb 10, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
Should I use a dry toothbrush or a swab damp with alcohol to clean cartridges?
Hi:
To clean the contact area or the print head on your ink cartridges, only use water, and a soft cloth or paper towel. A dry toothbrush can be used to gently brush the contacts in the printer, where the ink cartridges mount.
Dec 05, 2009 | HP DeskJet 895cse InkJet Printer
HP officejet Pro 7580 problems with streaking
Clean the electrical contacts on the printhead and inside the product The ink nozzles on the printheads might clog if they are exposed to air for more than a few minutes or if the product is not used for long periods of time. Follow these steps to clean the electrical contacts on the printheads. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product and stops. Release the OK button.
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet.
    NOTE: Do not turn the product off by pressing the Power button (c01346625.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01448109.gif
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle and remove the printhead c01448110.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
    1. Wipe the electrical contacts with the swab until no ink residue remains, and then wipe the electrical contacts with a fresh cloth to dry them and remove lint.
    2. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
    3. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01448112.gif
    4. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
    5. Plug the product power cord into the electrical outlet.
    6. Press the Power button (c01346625.gif ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
    7. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
    8. Pull the printhead latch all the way forward, and then press down firmly to engage the latch.
      NOTE: You might have to press firmly to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
    9. Close the top cover of the product. The product restarts and then prints an alignment page.
    10. Click on setup on the printer select tools and select clean printhead.
    11. inside the printer clean the metal carriage rod,rollers and that is it (clean with moist cotton swab)
Jun 22, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Cartidge?????
Make sure to remove the film from the bottom of the cartridge and here is how to clean the receiver on the printer.
1. do not use regular rubbing alcohol it contains 75% water and could damage the contacts.
2. use only a small amount with a soft cloth not cotton swabs or balls and clean the contact pins and surrounding area.
3. continue till the cloth comes clean and allow the printer to dry completely for appx. five minutes.
4. reinstall the cartridge and go to the printer section in control panel.
5. find your printer and right click on it, scroll down to properties and left click.
6. perform the head cleaning function under maintenance.
if this does not work let me know and we can walk through some of the solutions..Be mucho blessed..Mark
Apr 22, 2008 | Canon BubbleJet i320 Printer
HP Officejet Pro L7680 All-In-One Printer Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
