Question about Dewalt Drills
I put a short bit into my dewalt impact driver and now i cant get the bit out
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Switch to reverse and driver mode hold tight the chuck then run the drill just to jack it... be carefull the keyless chuck plastic that release is easy to lose its grip to the steel so be patient. goodluck!
Posted on Dec 12, 2009
SOURCE:
DeWalt 20 V impact. Driver ejects occasionally. Locks in correctly to start then after limited use, bit holder falls out.
These are known for the spring in the nose (#12) to fail.
Using an o-ring pick or small screwdriver remove the hog ring on the end of the bit holder (#17).
Slide the washer, spring, and sleeve off (Be careful not to lose the small lock ball)
The spring that pushes the lock ball forward (#12) is usually the culprit.
Reassemble in reverse order DeWALT DCF886D2 20V Impact Driver Parts
Dec 06, 2016 | Dewalt Drills
The chuck on the dewalt impact driver does not hold the bit holder in
If you go to dewaltservicenet.com you can enter your model number to see the parts breakdown. It can be tricky to get the retainer clip off and on but the rebuild of the bit holder is easy other than that. The spring and the steel ball are all that usually need to be repalced. Hope that helps.
Apr 20, 2014 | Dewalt DW056 18 Volt Cordless Impact...
How do i insert bit in cordless dewalt keyless hex chuck?
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
Oct 26, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt dcf885 will not lock the bits in
It could be the little spring at the back of the chuck sleve is broken ot one of the locking balls is missing.
Apr 01, 2013 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
Bit falls out of impact driver
There is a small spring at the back of the sleve which snaps. Try replacing it. it is only cheap.
Feb 02, 2013 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
Magnetic Extension for Dewalt Drill Bit
I have the same problem and am thinking of cutting that extension to get it out. A real pice of !@#$$%
May 13, 2012 | Dewalt DCF815S2 12-Volt Max 1/4-Inch...
How do i put a drill bit?
An impact driver won't work very well as a drill. In fact it will probably break drill bits in anything but very soft material (like drywall). A drill bit needs a smooth continuous motion, because it cuts continuously as it turns. An impact driver turns with a staccato motion.
Jan 19, 2011 | Dewalt DW056 18 Volt Cordless Impact...
How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
Jan 04, 2009 | Dewalt DW0521 Quick Connect Impact Driver...
Drills Logo
106 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
