Question about RCA P52960 52" Rear Projection Television
MODEL - P52960 RCA
My TV started blinking off and on. It finally stayed off and begin chirping until I unplugged it. Is this something that is expensive to fix providing my discription helped you to diagnosis the problem. Thanks for any help you can provide.
  • chris05 Mar 07, 2008
    found on the main board what looks to be a power supply that is burnt a little ,every thing else looks ok part# is 15307400 but cant seem to find it ?
  • 61 Answers
You have a flyback and horz output bad,price for this repair should be around 150.00 to 175.00,you also may just have a loose connection on the main board,if so price would be much less,because the flyback would not need replacing just the output
Posted on Mar 07, 2008
My rca projection 52" tv
http://www.partstore.com/OpenSearch/Model/Thomson/RCA.aspx
Jul 07, 2011 | RCA P52960 52" Rear Projection Television
Chirping sound and will not turn on
chirping sounds generally but not always indicate a faulty flyback transformer and a shorted horizontal output transistor. but it always first place I look to as a tech when it chirps
Nov 04, 2010 | RCA P52960 52" Rear Projection Television
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
Problem with RCA P52960
unplug tv from wall then turn back on
Aug 14, 2008 | RCA P52960 52" Rear Projection Television
Television set wont turn on .
labor and parts are around 200.00 us dollars.
Dec 23, 2007 | RCA P52960 52" Rear Projection Television
RCA 52 inch projection Model P52960
solder connections around the flyback most likely. That is a common fault with the PTK and CTC chassis. Hope this helps.
Dec 13, 2007 | RCA P52960 52" Rear Projection Television
TV WON'T COME ON
All the reports are showing the same problem the TV is in shutdown mode.
Something is wrong and it is refusing to start it makes a chirping or clicking sound. Solution is that it needs to be repaired nothing you can do unless you want to try replacing the motherboard yourself.
Dec 05, 2007 | RCA 24V511T 24" TV
My 52 in
Chirping is usually a problem in 2 areas of this unit. 1st check 3 legged regultor on the right side of the chassis, also 2 small transisters and 2 resisters near and in front of the regulator. RCA has a kit for this problem, the second is check the horizontal output transister is on a separate heat sink along side of the Flyback Transformer, it shorts and pulls down the regulator power supply.
May 28, 2007 | RCA P52960 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
