Question about Makita MAC5200 Electric Powered Air Compressors
Keeps shutting off, runs for a 10 or 12 seconds and throws the reset button
  • 530 Answers
There are a few things that will cause a compressor to trip the breaker.
The main one is by using an extension cord. Compressors pull a lot of juice, even small ones. Therefore it's recommended that you use a longer air line instead of an extension cord. If you need to use one then you need to get one that may seem overkill. The best place to find one is a boating supply shop. Shore power extension cords do the job nicely.
Another issue is related to where you live and the time of year. If you are in a colder climate (like me), then you may need to stick a space heater next to it for 10 minutes. Compressor oil is straight 30. Even if it's a "Oil-less" design.
If you are in a warmer climate then you shouldn't be messing around with a compressor unless it's to air up a raft. ":-}
The last problem has to do with the unloader valve. When a compressor reaches it's max psi there is a momentary pressure release. This is the pressure that remains in the compression cylinder and the tank check valve. With out this release the piston needs to work against the max psi when it starts. This will cause the motor to sound as if it's laboring. This lasts about 10 to 12 seconds then it trips the breaker.
However the compressor would need to have started and worked up to or close to max psi. Only after it restarts will it have this issue.
Yea I know it's a lot of info but I like to be thorough.
The only other things that might cause this is an electrical problem usually found when there are to many other items on the circuit. A compressor should have a dedicated circuit but that's not really practical with smaller portable compressors.
I hope something here helps but if not please let me know and
I'll try and figure out the problem with you.
Posted on Dec 23, 2009
SOURCE:
I have a babyliss hair dryer mod. 6619E type S54d The dryer turns on but after a few second it turns off What is the reason.
is it throwing a reset switch on its plug head? if so press the reset button on the plug head if it trips again there's an issue inside the hair dryer thats making it shut off power to it from the plug head
Apr 21, 2017 | BaByliss Dryers
Konica minolta bizhub c253,how to reset transferbelt by using fusser
There are two ways to reset an error code:
  • 1. Open the front cover, wait for a few seconds and then close it. If the error is still there try the second method.
  • 2. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.Restart it normally and it should work. If the error is still there, try to follow the steps provided in the solution found based on your error code.
Aug 21, 2014 | Office Equipment & Supplies
Clarke sander
Once we plugged it into an outlet with a trip switch it worked.
Jul 28, 2013 | Tools & Hardware - Others
Refrigerator keeps throwing receptacle switch plate
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
May 23, 2009 | Kenmore Refrigerators
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Makita MAC5200 Electric Powered Air Compressors Logo
458 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
Dennis Gaebel
Dennis Gaebel
Level 1 Expert
Craig Butler
Craig Butler
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
