Question about Zanussi FJS1225W Front Load Washer
Fjs1225w machine wont start
All the lights and buttons on the control panel work ok,but when the green start button is pressed there is its normal bleep and then nothing.I was told the door interlocks on this model are suspect so i have replaced it but it has not cured the fault.There are no fault codes being shown.Any help gratefully recieved.
  • 139 Answers
If its not the door interlock then the only other possible thing is the control module has failed ....
it does happen on zanussi machine.. is it making a cliicking noise the door interlock.... when you press start .... like click click....
if so then most likely its the control board inside the machine
Posted on Jan 21, 2008
Maytag 4000 series washer won't start, once you press the start button machine power off..
Power off means a short circuit. Either the PC controller board has a defective part or the safety electronic / shut down protection has indicated a fault and opens to prevent a fire, electrical damage, or other condition.
Feb 07, 2018 | Maytag Washing Machines
My philips 32PF5531D/10 TV Wont Work
i have same problem.. please if you had found solution help me help me!!
Mar 14, 2012 | Televison & Video
My hp deskjet 3550 is not printing. the green light at the power button keeps on blinking. What is the problem? both ink cartridges are full. there is no paper jam.
1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
May 28, 2010 | HP Color Laserjet 3550 Printer
To start Green light flashes. Pressing start button doesn't start the machine Mod 9410
if green light is flashing . the power is ok / look to bad interlock( door ) and bad touch control . some times it the connection to the main control moduel ( ck this ist's very common . / hope some of these help ****
Dec 23, 2009 | Dishwashers
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
Maytag washer panel show a red light that say control lock what if anything i can do to releaseit
Try the "End of Cycle" button to the right of panel front, next to Start button. Mine says hold for three seconds to lock/ unlock control.
Mar 10, 2008 | Washing Machines
Zanussi FJS1225W Front Load Washer Logo
270 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
