Question about Dell Latitude D600 Notebook
Just put in a new 320gb westerndigital hard drive and did not partition it when i had the chance and now it gives me a disk read error. Any help on how to fix problem without spending more money would be greatly apprciated. Thank you, Jason
  • jasonelder97 Dec 12, 2009
    The dirve is to large as the bios only sees 137 gb. The bios is locked and i dont have admin password. Any other suggestions. thanks
  • 495 Answers
Hello, I'd try a few things (non-money-costing).
  1. Check the BIOS. The drive may be too large. You may have to change the 'compatibility mode'.
  2. You need your BIOS set to CDROM first and HD second.
Hope this helps a bit. Let me know the results.
Posted on Dec 12, 2009
  • Braunson Y Dec 12, 2009
    Have you tried the default backdoor password Dell ? Try giving Dell support a call for a pasword, they're pretty helpful!
    Yet there is yet another way -- If you have the previous harddrive and it has a working operating system, you can use the program Christophe Grenier has written a program that will calculate the master BIOS password for Dell Latitudes from the Service Tag number. That program is available athttp://www.users.globalnet.co.uk/~skynet...
    Go into a command-session (or DOS-box) in any OS you like.
    Go to the directory with the LATITUDE.EXE program in it (size is only 5,467).
    Type in latitude 12345 and hit enter. You have to substitute 12345 with your 5-character service tag number. The program then gives you the password.Simple (if you know how to).Attached is a working version in a zip-file
    If you do the above, continue onto #2 of the previous post, and then try using your new OS cd as right now your computers booting from the harddrive not the CDrom, and as the Harddrive is empty, it returns a disk read error. You need to boot from the cd, and there from the cd install the OS to the harddrive.
How do I find and download software for SimpleTech 320GB External Hard Drive
What type of software are you looking for? When you insert the device, the system should recognize, and install the drivers.
Jan 11, 2015 | SimpleTech SimpleDrive Pininfarina 320GB...
How do i use my second partition of my hard drive? my laptop is a dell vostro 1088. It seems that my OS (C:) is full but i see that i have a new volume(F:) so how do i use that? Originally, my laptop...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Apr 23, 2011 | SIB 320GB 5400RPM 8MB Cache SATA Hard Disk...
When i am installing os it is getting struck & giving error like os(xp, 98,vista,2008) can not format drive or bad formated partition .it is 80gb ata HDD
Any "small" disk-drive, such as your 80GB disk-drive is "out-of-warranty".
If you are going to install an Operating System, spend $50 to buy a new disk-drive,
probably faster (7200 RPM versus 5400 RPM) and bigger (320GB versus 80GB)
than your "antique" disk-drive.
Dec 10, 2010 | Western Digital Computers & Internet
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
What is/can I do about a ''corrupted partition''?
Supposedly is not RAW will coming out, right! Either NTFS or FAT32. You cannot open your drive unless it is back into original format.
All you have to do, if you have a knowledge on how to remove the hard disk inside the Seagate Box (Freeagent) and then transfer it to your CPU. This devices is just like an HDD Enclosure.
Hope i help you this. Add comments if you want more information about this.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 18, 2009 | Seagate 320GB FreeAgent Pro FireWire 400,...
My westerndigital passport size hard disk of size 320gb when connected to system at starting 2 to 3 beep sounds i am hearing and the hard disk is not detecting what to do? naresh
Either the USB-to-disk-drive adapter inside the casing has failed,
or your USB port has failed,
or the disk-drive inside the casing has failed.
Try a different USB port. Try a different computer.
Disassemble the casing, and remove the disk-drive.
Temporarily attach it as a "slave" drive in a desktop computer,
and see if the drive is detected, and if the files are OK.
If all else fails, and the Passport is still under warranty, exercise the warranty.
Apr 15, 2009 | Western Digital Passport 320GB External...
WD External Hard Drive 320GB Cyclic Error
Windows Delayed write file error
Read this
http://support.microsoft.com/kb/330174
since your talking about the External drives, a lot of reasons makes this happen. if the resolution above link cant help you, then try this:
Make sure that update the driver of your PC hard drive. Usually, this errors appear if your moving from one hard drive brand to another ex: seagate to samsung etc....
updated hard drive driver resolve this.
Make sure the cables are alright. Or at least have the latest service pack. USB drivers causes issues as well. I updated mine and the problem did not crop up anymore. hope this would help.
Feb 22, 2009 | Western Digital Elements powered by WD 320...
Unable to Format WesternDigital USB Hard Disk
Are you formatting a new disk or an existing one? Keep in mind that the rest of us do not know all the details that you know unless you tell us & thus it will take much longer to resolve your issue.
You said "after you tried it with XP CD". Dont know what you mean. What program did you use the first time & what steps did you do?
Nov 21, 2008 | Western Digital External USB 2.0 80 GB...
My Samsung HDD SP0802N 80 GB PATA says read error and not booting
dear suresh
just trying using hdd utility like partition magic or with disk management in window
but i supposed to fixed it in another pc , you can partition it with two or three partition
after that youcan format it
oke
cropp
Mar 18, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Dell Latitude D600 Notebook Logo
24 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
