Question about Miele DG 4080 Stainless Steel Electric Single Oven
Fault 23 is displayed on the control panel after using teh self clean function on our miele double OVEN H398 BP2. IT IS NOT LISTED ON THE MANUAL WAHT DOES IT MEAN?
    Problem Solver:
  • 15 Answers
F23 means that the required pyrolitic temperature was not reached during the self-clean cycle. If the other half of the oven does not do this, then it could be a problem with a door lock switch or one of the overtemp sensors.
Posted on Feb 27, 2010
Testimonial: "Thanks - I am sure there is a temperature problem as this oven is cooking much slower all round."
  • FiFi22 Apr 23, 2011
    I have the same problem is there a simple fix or does it require a service call?
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 28, 2010 | Miele H398BP2 / H398B2 Electric Double...
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
After self cleaning my oven i have a fault code F32 what does that mean?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 17, 2010 | Miele H398BP2 / H398B2 Electric Double...
Oven beeped by itself and display went blank. Pushing any buttons only results in beeps. The oven controls aren't accessible and the oven doesn't actually turn on for use. We haven't used the self...
Hi- Wow - Honestly wish i had good news, but this is a little different critter. The touch membrane is connected to control board by a ribbon tape with a whole bunch of little contacts that can become corroded, affecting proper function. Display failure is usually a control fault, however, and unfortunately this board is one of the most expensive to replace. - Bravo on not using the 'self-destruct' function.-  The control still routes all the power through it's circuits, and failures under normal use are not uncommon.  Best option is a service call from a good tech in your area. This is a tricky one to diagnose. Find out cost to fix before repair.  Let me know if this info helps ya, have more if needed- Thanks-  Ed
Mar 16, 2010 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Miele DG 4080 Stainless Steel Electric Single Oven Logo
1,478 people viewed this question
Top Miele Ovens Experts
Paul Bade
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
