Question about Canon PIXMA MP160 All-In-One InkJet Printer
El scaner ARTEC ViewStation AS6E para Windows Xp pero en puerto
Escaner ARTEC ViewStation AS6E para Windows Xp no lo reconoce.
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
Al conectar la maquina por puerto usb con sistema operativo windows 7,no carga el scaner, siempre da fallo en display de desconexion por lo que percibo no tiene controlador quisiera saber como lo obtengo...
Saludos aparentemente el problema esta es que el scanner no tiene drives para el windows 7. Te sugiero que vuelvas a la pagina de HP y trates de bajar con el sistema opertivo d Vista ya que este es el mas cercano al sistema que usas. Trata de sacar el programa en tu computadora , vuelves a instalarlo. Suerte!!!
Jan 30, 2011 | HP PSC 500 All-In-One Printer
ACABO DE ADQUIRIR UN COBY MP727, SI ACEPTA LA CARGA POR MEDIO DE LA COMPUTADORA PERO NO RECONOCE EL USB PARA EL ENVIO DE MUSICA
tiene que o?r el equipo hace un ruido cuando se conecta el USB en el puerto. si esto no ocurre, usted tiene un puerto USB muertos. si usted est? escuchando el ruido cuando se conecta el USB a la computadora luego contin?e con el siguiente p?rrafo.
si est? usando Windows XP, vaya a "Mi PC" y el dispositivo debe aparecer como otro disco duro, al igual que tu (Disco local (C:)), disco duro interno. Usted puede abrir este al igual que una carpeta y desde all? debe ser capaz de colocar la m?sica en el dispositivo.
Jan 09, 2011 | Coby MP727 MP3 Player
Al querer instalar wxp-sp2 me aparece el mensaje que no encuentra ningún HDD, pienso que es porque no reconoce los drivers. La máquina es una Laptop Dell Latitude c840 y el HDD es un...
Creo que ese laptop no supporta SATA para XP, y se puede tratar hacer lo con un cambio en BIOS.
Prende el laptop, y empuja "F2" inmediatamente cuando aparece el Dell logo. En el setup menu en BIOS empuja "SATA native mode" para tenerlo apagado.
Inserta el Windows XP CD en el CD ROM drive, y apagar y apagar el lapto.
Jan 14, 2018 | Hitachi TravelStar DK23EB Series DK23EB-40...
No se puede copear ninguna cancion a mi reproductor
Usted debe asegurarse de que el CD de instalaci?n para su reproductor de mp3 se ha instalado. Usted no puedo copiar nada porque el equipo tiene problemas para reconocer su reproductor de mp3 o puede haber un ajuste en tu mp3 que s?lo permite que el dispositivo de "s?lo lectura" ir en su ordenador y haga clic derecho en el dispositivo y seleccione Propiedades. desde all?, desmarque de s?lo lectura y que en caso de que deje ahora.
Lo siento si mi espa?ol es malo. Estoy usando Google Translate para escribir porque no puedo hablar espa?ol, pero puedo entender y leer.
Espero que esto ayude : )
Dec 30, 2010 | Memorex MMP8561 (1 GB) MP3 Player
No enciende, no muestra nada en la pantalla
lo mismo me pasa a mi no enciende pero el ordenador en este caso si lo reconoce pero no se como hacer para que encienda normalmente!!!!!!!!
Oct 12, 2010 | SanDisk Sansa m240 MP3 Player
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Tengo la webcam Philips SPC 600 NC Y TENGO EL WINDOWS 7 GRACIAS PERO NO ME RECONOCE LA WEBCAM DE PUEDO HACER EMAIL
esto es la Fixya ingles. Necessita el espanol sitio para consejo mejor. por favor repetir su buscar en espanol. Lo siento.
Dec 23, 2009 | Microsoft Windows Vista Ultimate Edition
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Disco duro serial ata
Hola VooDooNOFX
Gracias por la ayuda
No estoy configurando los dos discos duros apartes ni haciendo raid a los dos juntos.
El D.D. de 80 gb IDE ya esta parcicionado y formateado (40 c/u, FAT32), tiene windows xp sp3. Uso teclado PS2.
En el D.D. 250 gb serial ata quiero particionarlo en cuatro partes e instalar windows vista, las otras tres particiones para datos.
Voy a hacer esto: Desconecto el D.D. 80 gb IDE y dejo solo instalado el D.D. serial ata de 250 gb para partionarlo y formatearlo con windows vista; primero sin desactivar la función de raid en la bios y luego desactivandola; que opina.
Sep 16, 2008 | MSI Microstar KT6 Delta (MS-6590)...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
116 people viewed this question
old marine
old marine
