Question about Linksys RangePlus WRT100 Wireless Router
I had an old G series Linksys and was experiences poor performance so I upgraded to the WRT110 N series and immediately I was pleased that my computer was finally running at a speed I was happy with. It ran great for a week and then suddenly things changed. I cannot stream video or download a simple program with having to wait hours. Web pages open so slowly I am angry every time I try to use the internet. Did my settings get changed? Why did things suddenly go so wrong?
  • 345 Answers
This is usually sign of firmware update. just reset it to factory settings by pressing in the reset button for 30 sec usually found on back of routers. be careful because if u have done any changes in the router it will be erased. i believe there is option to save the router file to save the settings and import it once .router is reset. Make sure it is not ur pc that is the problem before reset. try different pc good luck.
Posted on Dec 12, 2009
I have an emachine and installed airlink 101 ,,keeps kicking me off line..what do i do? i am online for 5 minutes then it kicks me off IE. says i am still connected.. HELP!! thanks
The following wireless access points/routers have been tested for use with the SoundBridge and SoundBridge Radio. While Roku is unable to provide testing results for all available wireless access point and routers, the vast majority will work fine with your SoundBridge product. We encourage you to try using your SoundBridge with your existing wireless equipment, regardless of published result before replacing your current hardware.
The current SoundBridge models, M1001 (connections on the back) and SoundBridge Radio R1000, use different wireless hardware than the older M1000, M500 and M2000 models (connections under the endcaps). This newer hardware has proven considerably more reliable than the older wireless hardware and should work out-of-the-box with virtually any 802.11b-compatible wireless equipment you may have. Compatibility of the older hardware has been improved over time and we recommend that you upgrade your SoundBridge's software to the latest version as soon as possible, particularly if your SoundBridge was delivered with software older than version 2.3.44. Upgrading older software may require using a wired ethernet connection or even taking your SoundBridge to a neighbors house or your office to sucessfully perform the upgrade.
To check your software version and perform an upgrade, use your SoundBridge remote control to navigate to the menu Change Library or Configuration -> System Configuration -> Software Version and Updates and follow the on-screen instructions.
If you still experience Wi-Fi connection problems, check the following items:
  • Make sure your access point/router is configured to allow 802.11b devices to connect. This may be phrased as "Mixed mode" or "802.11b +802.11g".
  • If you have wireless security enabled, make sure it is a supported protocol, and make sure you are using the "Hex" key. See your SoundBridge manual for more information.
If, after checking these items, you still cannot get your SoundBridge to connect to your wireless network, we encourage you to contact support or visit our Roku Community Forums where other customers and Roku employees will attempt to help you.
Bold = recommended by Roku for use with the latest version of SoundBridge software.
Red = poor performance or incompatible with SoundBridge
* = customer tested - your results may differ.
Model M1001,
R1000
M1000,M500,
M2000
Notes Airlink101 AR410W Yes Yes Fast! Apple Airport Extreme (Snow) Yes Yes Buffalo WBR-G54 Yes Yes Very reliable Buffalo WBR2-G54 Yes Yes
D-Link DI-514 B1 Yes Yes
D-Link DI 624 Yes Yes D-Link DI 784 Yes Yes D-Link DIR-655 * Yes Yes Set to b/g or b only. Problems reported in b/g/n mode. Linksys WAG300N * Yes Yes Disable wireless AP isolation. Linksys WRT51AB Yes Yes
Linksys WRT54G Yes Yes
Linksys WRT54GC Yes Yes Linksys WRT54GS Yes Yes Works great Motorola WA840G Yes Yes Works great Motorola WR850G * Yes Yes Wireless mode should be set to Compatibility. Problems have been reported with using Performance wireless mode. Netgear DG834Gv3 * Yes Yes Firmware v4.01.06 may be required for internet connectivity and WPA. Netgear DG834G Yes Yes Netgear WGR614 v5 Yes Yes Netgear WGT624 (all hardware revisions) Yes Yes Netgear RangeMax WPN824 Yes Yes Works great. Siemens GigaSet SE361 * Yes Yes SMC SMC2804WBRP-G Yes Yes Needs firmware v 1.956 or greater SMC SMC2804WBR Yes Yes
USR 8054 Yes Yes Needs firmware v 1.64 or greater XRouter Aero WSR-5000 Yes Yes ZyXEL Prestige 335WT * Yes Yes AirLink AR315W Yes Yes Poor performance Airlink AR420W * AP/Router/Switch No
AVM 3070 * AP/Router/Switch No
D-Link DI-524 AP/Router/Switch No Some users report this router works fine for them. Linksys BEFW11S4 No No. Performance is unacceptable Linksys WRT54GL * No No Downgrading to original firmware fixes rebuffering issues. Linksys WRT54GP2 Yes Yes Very slow performance Linksys WRT55AG Yes Yes Works, but some customers have reported issues with accessing the Internet through this device Netgear FVM318 Yes Yes May work for some, does not properly route UPnP discovery packets between wired and wifi Netgear MR814V2 Yes Yes Poor performance Netgear WGR614 v4 Yes Yes May require B-only mode . SpeedTouch 716G * Yes Yes Can connect wirelessly and stream locally, but no internet access. USR 5462 Yes No
Note: If your wireless access point does not work well with the SoundBridge, please make sure that both the SoundBridge and the access point are using the latest firmware available.
Apr 20, 2013 | Computers & Internet
Lost password
reset Linksys to default settings. User manual : http://static.highspeedbackbone.net/pdf/Linksys-WRT110-manual.pdf Reconfigure SSID and Security. You may want to write down Security Key for future use. A tattoo is a option, it's your choice.
Jan 02, 2013 | Linksys WRT110 Wireless Router
Dsl modem = to 3 linksys wrt110 routers for wi-fi ?
What you are trying to do is a rather big job. Hire a company to connect the equipment properly. The headaches you save will be your own. If you install it, you will have to fix it everytime it goes out if you contract someone to install it and you buy a support contract when they install it, THEY get to come fix it and the headache is theirs, not yours. And NEVER install that type of router in an attic, they will overheat and fail very quickly.
Oct 19, 2012 | Linksys RangePlus Wireless Router WRT110 -...
I have to reinstall my linksys router wrt110 and i have no instalation cd
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
I suggest that you click on the following link and download the Linksys setup wizard: Linksys Setup
The following link will hook you up to the largest FREE database on the Internet: Free Driver Downloads
All the best
Ben
Sep 07, 2011 | Linksys WRT110 Wireless Router
What is the Internet speed of the linksys router model WRT110
Linksys Router WRT110 supports Wireless G plus MIMO and it will have a maximum transfer rate of 108Mbps (double the size of regular Wireless G routers)
CreativeTECH
Dec 08, 2010 | Linksys Computers & Internet
CANT ACCRS WIRELESS ROUTER WRT110 BY LINKSYS CISCO
Sounds like the router needs to be reset..
Before you do a reset try to login to the router by typing 192.168.1.1 in the webrowser ..
If that fails then look on the back or under the router and there is a reset button. Press and hold for 10 sec ... The let sit for a min or 2 then try logging into it..
Note: That the router will have to be setup again. Default login admin for the password .. don't enter any usernames
Jul 22, 2010 | Linksys RangePlus Wireless Router WRT110 -...
My wireless router
Perform a hard reset, check to see if you're running the latest firmware, if not upgrade.
If you still have problems contact Linksys tech support.
May 22, 2010 | Linksys RangePlus Wireless Router WRT110 -...
Well if these computer is connected to one of the lan ports on router computer light should be on it also depends on who your internet service provider is?But light should be on regardless indicating that it is recognizing computer.Try totake it back to point of purchase.
Aug 26, 2008 | Linksys Computers & Internet
Linksys RangePlus WRT100 Wireless Router Logo
97 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
