Question about Onkyo TX-NR905 Receiver
Left front and right front speaker outputs not working NR905
5 Suggested Answers
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: Speaker output
My unit does the same thing, I read online to install a RCA Patch cord from Main-In to Main Out and it worked.
I contacted Yamaha and they wanted to charge me to fix the issue and they will not fix it under warranty because I did not buy the unit from a authorized Yamaha dealer. Obviously a design flaw.
Posted on Jan 07, 2008
gpgab97
  • 77 Answers
SOURCE: Only one speaker working on my str-de675 receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
Posted on May 03, 2009
yammy_alf
  • 666 Answers
SOURCE: Right front channel not working
try to check balance adjustment if working.
Posted on Apr 16, 2010
Need to wire up a factory radio plug for 2003 chevy tahoe z71 with bose premium system. need to know what wire gose in what pin in the plug. SOMEONE PLEASE HELP ME!!! PLEASE!!!
Connector Part Information
12110088 (Except UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRY) (Except UQ7 w/o Y91)
15428074 (UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRN) (UQ7 w/o Y91)
Pin
Wire Color
Circuit No.
Function
A1
ORN
1044
Radio Class 2 Serial Data
A2
Not Used
A3
PPL
493
Rear Seat Audio Enable Signal (UQ7 w/o Y91)
A4
RED
1486
FM Composite Signal (UQ7 w/ Y91)
A5-A7
Not Used
A8
TAN
201
Left Front Speaker Output (+) (UQ3/UQ5)
A8
TAN
511
Left Front Low Level Audio Signal (+) (UQ7)
A9
GRY
118
Left Front Speaker Output (-) (UQ3/UQ5)
A9
DK GRN
1947
Left Front Low Level Audio Signal (-) (UQ7)
A10
LT BLU
115
Right Rear Speaker Output (-) (UQ3/UQ5)
A10
BLK
1946
Right Rear Low Level Audio Signal (-) (UQ7)
A11
DK BLU
46
Right Rear Speaker Output (+) (UQ3/UQ5)
A11
DK BLU
546
Right Rear Low Level Audio Signal (+) (UQ7)
A12
BLK/WHT
1851
Ground
B1
ORN
340
Battery Positive Voltage
B2
Not Used
B3
PNK
314
Radio On Signal (UQ7 w/o Y91)
B3
DK GRN
145
Antenna Enable Signal (UQ7 w/ Y91)
B4
BRN/WHT
230
Instrument Panel Lamps Dimming Control (w/ Y91)
B5
BLK/WHT
1851
Ground (w/ Y91)
B6
GRY/BLK
2334
Radio Mute (UQ7 w/o Y91)
B7
Not Used
B8
BRN
199
Left Rear Speaker Output (+) (UQ3/UQ5)
B8
BRN
599
Left Rear Low Level Audio Signal (+) (UQ7)
B9
YEL
116
Left Rear Speaker Output (-) (UQ3/UQ5)
B9
DK GRN/
WHT
1547
Left Rear Low Level Audio Signal (-) (UQ7)
B10
DK GRN
200
Right Front Speaker Output (+) (UQ3/UQ5)
B10
ORN/BLK
1546
Right Front Low Level Audio Signal (-) (UQ7)
B11
LT GRN
117
Right Front Speaker Output (-) (UQ3/UQ5)
B11
LT GRN
512
Right Front Low Level Audio Signal (+) (UQ7)
B12
Not Used
Oct 20, 2015 | Cars & Trucks
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
Wiring diagram pioneer dxt-2369ub
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Nov 30, 2011 | Car Audio & Video
My tx-nr905 recievers output audio goes out when connected to my projector and a dvd player, but its ok with any other output combo; proj/sat or tv/dvd or tv/sat etc..... bought new about 4 yrs ago, has...
Semantics maybe, but sources are INputs. OUTputs are speakers, audio to other devices.
A DVD is always an INPUT.
So what's different? IOW, how are the DVD and Projector (Really? It uses a video OUTput) connected for audio? Have you looked at the manuals? Digital sources must be assigned, for example.
Aug 25, 2011 | Onkyo TX-NR905 Receiver
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Onkyo TX-NR905 Receiver Logo
64 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
