Question about Motorola Mobility RAZR V3
How do you take your calls forwarded to another phone OFF?
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
Feb 11, 2017 | Samsung Cell Phones
Cancel call forward
to cancel intercom call forward press the call forward key again or feature #4
to cancel a line call forward choose the line and dial *73 or whatever the phone company's cancel call forward code is (may be in phone book)
Feb 10, 2015 | NorStar M7324 Telephone
How do I forward calls from Panasonic KXTG4500 to my cell?
Call forwarding needs to be activated by your phone company and then set up through your account settings. The phone itself cannot forward calls. You would need a two-line phone with call forwarding features and two separate phone lines to accomplish call forwarding locally.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Feb 02, 2015 | Panasonic KXTG4500B 5.8 GHz 4-Line Corded...
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 | Cell Phones
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    How do I undo call forwarding on an RCA 25415RE3-A telephone?
    Call forwarding is a function of your service provider. CALL FORWARD VARIABLE you control by dialing a code then then number you wont to forward your calls to, *72-685-2900. To disable the forward dial *73. There are different codes for each phone company, you may have to contact them for the code they use.
    Another type of forwarding is setup by the phone company, CALL FORWARD BUSY/NO ANSWER. This type of forwarding you have to call the customer service line at your phone company to have them remove it. I use this type for my voice mail and call routing service, All Call Technologies.
    Apr 03, 2010 | RCA 25415RE3 Phone
    Call Forward not working
    Sounds like an IPK2. try just entering the forward destination in the first 2 fields. Why would the person being forwarded need calls? If you are forwarding his phone he can't receive calls. unless your just forwarding to vmail. cheaper rates at ldtsnj.com
    Mar 19, 2009 | NEC Electra Elite 32D-1 Corded Phone
    I need to retrieve my home phone messages from cell phone
    2. Press *7 2.
    In some areas you must use 72#
    3. At the tone, dial the telephone number where you want your calls transferred.
    Deactivating Call Forwarding
    Turn Call Forwarding off when you want to receive calls on your home phone.
    2. Press * 73.
    In some areas you must use 73#
    Dial 1173 on rotary or pulse-dialing phones.
    3. Listen for two short tones.
    Call Forwarding is now off and you will receive your calls at your home number.
    Dec 01, 2008 | Uniden Cordless Phone
    Motorola Mobility RAZR V3 Logo
    29 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    vince
    D. E. Hev
    Steve Berry
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
