Question about Dryers
I have an Amana electric dryer that is not starting, have motor removed from dryer cabinet, armature is very hard to turn and squeaks when I do turn it. Is the motor probably bad?
  • theimburger Dec 12, 2009
    Thanks. I'll amplify on the symptoms. This is a 15+ year old Amana dryer model LE4427W. A week ago the dryer would not start and we heard a humming noise. Then it started and ran fine after several attempts at different dial positions. The problem came back a couple days ago and this time we could not get it started and the motor was no longer even humming. I read a number of posts on this site and others that nearly all point to a likely defective motor. But a couple suggested I might try cleaning it and trying it again, though this might only be a temporary solution. I cleaned the motor as well as I could, and oiled the armature with 3-in-1 oil this afternoon and the squeaking went away, but still pretty hard to rotate the axle from the attached blower fan. I found a printed the Amana service manual but the electrical troubleshooting procedures for the motor are a bit beyond my skill level. My plan right now is to reassemble and test again now that it's clean. How should I check the input voltage?
  • 288 Answers
It seems from what you are describing that there is not enough starting torque to turn this motor. It does sound bad and I would or would have someone check the supply voltage going to the dryer so you do not have a similar problem with a new motor
Posted on Dec 12, 2009
  • tim dulany Dec 15, 2009
    you can check the dryer plug for voltage with a voltmeter. If it is a 15 year old dryer, it may simply be worn. the motor consists of a rotar(which is a steel bar that spins inside a coil at a high speed) and a stator. this is a very precise fit and unfortunately, they wear out. you can also check this with a clamp on amp meter and see if you are within 10% of the rated amperage of the dryer. It should be on a dataplate on the back
SOURCE:
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer making squeaking noise, what causes this?
The squeaking could be coming from the idler pulley on the motor, the drum rollers or a worn drum seal. It is not a good idea to spray the rollers with WD-40. The WD-40 will attract lint that will build up and could catch on fire inside the dryer cabinet. A bad drum support roller or any other squeaking component inside a dryer cabinet will normally need to be replaced.
Aug 29, 2011 | Maytag Neptune MDE6700A Electric Dryer
Drum dose not turn.
sounds like the belt or motor, need to take it apart, the belt should be in the middle of drum if it is then more the likely it is the motor, you can disconnect belt pug dryer in and see if the motor spins, there may be a reset on the motor, if so it is located where the wire come in. Here is a website that that will help with the cabinet removal and some other things that could cause the problem:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 25, 2010 | Amana ALE643RB Electric Dryer
I have a ALE 866 dryer and everytime we run it, it is making a loud squeeking sound
Hello- The squeak is most likely coming from the drum rollers which are located under the drum in the rear; these often become sticky due to the heat and dust inside the dryer. It is usually best to replace them once the machine is opened up though sometimes the bearings are ok and one can just remove the wheels and clean the roller shaft with a green kitchen scrubber. The best lube to use is graphite because it does not break-down and get gummy with the heat generated by the dryer. The drum has to be removed in order to perform the service and Maytag (AMANA) belts are very tricky to put back on so I would suggest having a Tech out to accomplish this. They could also clean the inside of the dryer cabinet of lint and check the belt and other components for wear at the same time. Best regards.
Sep 27, 2010 | Amana ALE866SB Electric Dryer
I have an Amana NDE2330AYW dryer. It squeaks
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS If your a Handyman then this will be no problem to you. Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 04, 2010 | Amana NDE2330AY Electric Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
Dryer starts then immediately stops
sounds as if your motor is overheating nad shutting off.. willl it restart right away??? or will make you wait 20 min before restarting again only for 20 secs??? if so thats a bad motor
Mar 28, 2009 | Amana ALE230RAW Electric Dryer
Dryer motor is squeaking
Most electric motors do not squeak perse. I suspect the culprit is a worn out drumretainer bearing and or retainer assembly. This is the device that is mounted on the back of the drum and back of the dryer cabinet to hold the drum level and centered. It could also be the belt especiallyif the motor has become out of alignment from a broken mounting bolt if your unit is in a high moisture concentrated area.
Hope this helps.
Sep 04, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
