Question about Frigidaire GLEQ2152ES Electric Dryer
Hi I am trying to troubleshoot my Amana dryer - based on posts on this site suspect a bad motor. Have motor removed from dryer, can you help me do an assessment (non-electrical first)?
  • theimburger Dec 16, 2009
    never mind, have already ordered new motor, thanks.
  • Mark Egan May 11, 2010
    What was the motor not doing? Do you have, and know how to use, a volt-ohm meter? What tests have you performed on the dryer?
    President:
  • 1,214 Answers
Let me know if that doesn't fix it.
Posted on Dec 16, 2009
SOURCE:
Amana dryer model # NED 4500 VQ2. Coil does not turn off when door is opened. Have replaced door switch, thermal fuse, therm. cut-off, timer
Tom is the motor that turns the drum on any good? Based on what you've shown, that the part that's not working...the motor to turn the drum. If the motor is good, then maybe there is a control that is keeping the motor from turning on. No they don't usually go bad, but from here it's hard to see anything else. Hppe that helps.
Oct 14, 2014 | Dryers
Hello Fixya, I just moved and my new place has an amana 120-V Gas Dryer, that turns but won't heat. Ignition would bes suspect #1. Any great ideas? Thanks much, Rob
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 31, 2011 | Amana ALG866SB Gas Dryer
My dryer is less than 2 years old and is only buzzing when I try to start it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 21, 2011 | Amana ALG331RAW Gas Dryer
I sensed a bad burning smell from dryer motor. The dryer drum belt is still looking good and tight. The 4 drum rollers supporting the drum are looking good and no friction. The dryer shut itself...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Whirlpool LGB6300 Gas Dryer
Amana gas dryer model dlg330raw will not start. Doesn't do anything or make any noise no matter what setting it is on.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 15, 2010 | Amana DLG330RAW Gas Dryer
My amana dryer stopped working in the middle of drying and when i press the start button to come back on it makes a buzzing sound what could it be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | Amana DLE330RAW Electric Dryer
Have AMANA dryer ALE230RAW. Hear buzz when start
I also have this problem, but it is after the dryer has been running. When the motor is hot, it buzzes and will not run. Sometimes it will run if I turn the drum or take some clothes out. I disassembled the dryer and cleaned the motor of lint. This helped but not completely solved the issue. I have completely removed the motor and will thoroughly clean the motor (stator and brushes) and will try again.
Nov 23, 2009 | Amana Dryers
I still need instructions on how to remove the motor
hi. not unless the blower is jammed with something.the top comes of, the front comes off the drum comes off replace the motor. if you need my assistance lets chat. thanks
Oct 12, 2008 | Roper RGX4634KQ Gas Dryer
Rag lost under dryer filter
Sall, there should be a lower panel on this dryer that can be removed. Two screws on the bottom and it should pull out and down. Once the panel is off you will be looking at the blower housing. With the filter out, remove the screws securing the blower housing and lift out. Now the blower wheel is exposed and you should be able to see the rag. Catriver..post back.
Mar 28, 2007 | Amana ALE643RB Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
66 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
