Dayton torpedo heater blowing flames
Kerosene torpedo heater is blowing flame out past the heater plate and guard, and is blowing black smoke. I opened it up and turned down the amount of fuel, but when I got it down to the point that it wouldn't blow flames out, it stalled, and would not re-ignite. I just bought it brand new at an equipment auction so I can't exactly return it.
Therinnaiguy
  • 1420 Answers
SOURCE: Dayton Infrared natural gas heater ignition/flame sensor
Yes, the flame sensor is part of the intermittent pilot assembly. Check the following: make sure all grounding wires are secure and no corrosion is built up on them. Clean or replace the pilot assembly, also clean out the orifice with a very small drill. Make sure the sensor is in the flame and make sure the pilot tube is not leaking gas reducing the gas pressure at the pilot.
If it continues, you will have to replace the ignition control.
Posted on Nov 26, 2007
  • 90 Answers
SOURCE: when i turn on the heater it just blows smoke
if the unit has a high voltage transformer that ignites the flame. ie it has a heavier wire plugged into a spark plug or igniter. the coil is likely bad..... it should arc as soon as it is turned on. later models have a heater that gets very , cherry red, hot and that ignites the fuel. take the top cover off and you should be able to identify which you have. coil sets right under fan. one heavy wire and two light wires as the primary. light wires at about 12 ohms and heavy wire to chassis in the k ohms.
Posted on Jan 26, 2008
  • 2976 Answers
SOURCE: Won't ignite and fill the entire tube with flame, cold air, smoke
The deisel fuel hogged it up. Clean everything out and replace the wick. Deisel fuel is filthy to burn and it needs a lot of airflow.
Posted on Jan 16, 2009
muttandjeff
  • 359 Answers
SOURCE: No heat, just smoke, flame inside,
MORE THAN LIKELY NEEDS SERVICED START BY REPLACING FUEL NOZZLE WITH THE SAME NUMBERS THAT ARE ON THE OLD ONE SHOULD HAVE 2 NUMBERS ON IT DEGREE AND GPH RATING MATCH BOTH GOOD START AND LEAST EXPENSIVE AND MOST COMMON PROBLEM FOR WHAT YOU DESCRIBE
Posted on Jan 17, 2009
SOURCE: kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Posted on Jan 26, 2009
My Dayton 110,000 btu kerosene torpedo heater... The fan kicks on for a couple secs then kicks off it seems as it's not getting any fuel what should I do
Could be the Flame out sensor cutting the power to the electrics and therefore the forced air fan. It forces the heater to shut off should the flame extinguish. It might also be the temperature limit control which also turns the heater off if the internal temperature rises to an unsafe level. If either of these two possibilities the unit may need a service.
Dec 09, 2014 | Heating & Cooling
I ahvea reddy heater 70000 btu ,the fan is blowing but no flame
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 01, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
It is kerosene, it ignites, runs from 1 - 5 minutes and loses flame
heatman101
Dec 14, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
55000 reddy heater unsteady flame
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 03, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
390 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
