Question about Garden
How to install the 1/2 X 36" drive belt - Garden
  • drobert1 Dec 12, 2009
    I tried to include the fact that this is an Ariens snowblower model 910013. The problem is that there is no easy way to get the belt past the spline shaft, the cog connectors are in the way and therefore the belt can't be looped around the main drive pulley. I fear that something has to be pulled apart. I need to know what that is. Perhaps the whole auger section needs to come off. If so, is there a procedure.
  • 8,404 Answers
You don't mention the make or model of the mower nor the make of the engine. If you bought an exact replacement belt for your machine, this should be pretty straight forward job. The belt and mower were made for each other!
You will have a pulley, probably with a clutch device, attached to the engine and there will be a pulley on the transmission. Put the belt over these two pulleys. BE careful of any plastic fans you encounter. You will have slack in the belt. With your finger pressing against the inside of the belt, follow the path it COULD take while looking for a idler pulley. Use eye protection - it is dirty under there and get a drop light to help you see.
The idler pulley will probably be spring loaded requiring both hands to pull against the spring. The belt will ride INSIDE (outside of the belt presses against pulley) or OUTSIDE (inside of the belt rides against the pulley) this pulley. You should recognize the proper path when you find it.
You may have to try this with both the "parking brake" and the clutch both engaged and free wheel or locked and unlocked positions. It may help if you have a helper who can press the foot petal / operate the hand lever while you do the dirty work. WATCH YOUR FINGERS!!!!!!!!! AND MAKE SURE THE ENGINE CANNOT START - I suggest you disconnect the spark plugs.
I offer these variations because I don't know what kind of engagement equipment you have.
If you don't have an electric clutch, you have a manual engage system. In this case you will have a pulley on the motor, one on the transmission one that rides on the manual clutch device and maybe a idler pulley. Follow the same process I descrived above.
If you need more guidance with this, please post a comment outlining your concern to this quesiton and I will do some more work on this.
Thanks for your interest in FixYa.com
Posted on Dec 12, 2009
  • A Miller Dec 12, 2009
    Well now ... that is a horse of a different color.
    The snow blowers I am familiar with used a different drive mechanism. I went to Ariens to look for the information you need - I don't have your serial number so I cannot look at the electronic manual they offer on line.
    Here is the link where you can go to see the manual which I am certain describes the procedure. http://apache.ariens.com/cgibin/ctrg0005...
    You may haave to go in here, however, http://www.ariens.com/corporate/pages/cu... and select download manuals.
    I hope this helps you ... if you need more - please post another comment to this question so I can try again. (hee hee hee - I don't make the $ if I cant help you)
    Serioiusly, thanks for the clarification ... and think snow ... next week.
    Thanks
    a (from the Jersey Shore)
Where is routing belt located on Hyundai Sonata 2001 Alternator?
I believe you are referring too the Accessory Drive Belt for the Alternator...See attached drawing
25629874-2mhejhdcommskt1vzkafo1v3-3-0.gif To Remove:
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 05, 2015 | 2001 Hyundai Sonata
Install a belt tensioner in 2004 freestar
2004 Ford Freestar:
Accessory belt drive removal and installation:
    1.Put the vehicle in neutral, and put it on hoist.
    2.Rotate the accessory drive belt tensioner counterclockwise.
    3.Push the spring clip towards the belt tensioner to lock the accessory drive belt tensioner in place and remove the belt.
    4.To install the accessory drive belt, on the engine, rotate the accessory drive belt tensioner counterclockwise till the spring clip releases.
    5.Install the belt.
Jan 31, 2015 | 2004 Ford Freestar
Belt replace instructions
The accessory drive belt is a serpentine type belt that is driven by the crankshaft pulley
The belt drives the A/C compressor , alternator , power steering pump and water pump . Belt tension is maintained by an automatic belt tensioner .
Removal:
1. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be removed from pulleys .
2. Remove accessory drive belt .
Installation:
NOTE: When installing drive belt on the pulleys, make sure that belt is properly routed and all V-grooves make proper contact with pulley grooves.
1. Install the accessory drive belt around all the pulleys except for the alternator pulley.
2. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be installed on the alternator pulley .Release spring tension onto accessory drive belt .
Jul 23, 2014 | COMPASS 2008 AUTOMATIC REMOTE ONE WAY...
How do I get a diagram to show me how to put a serpentine belt on a 1998 Ford Escort Station Wagon?
you ask here. Please rate highly
SECTION 303-05: Accessory Drive 1998 Escort/Tracer Workshop Manual
REMOVAL AND INSTALLATION Belt -2.0L SPI Removal
  1. Relieve the drive belt (8620) tension.
    • Use a (A) ratchet or breaker bar inserted in the square hole in the drive belt tensioner flange.
    • Rotate the (B) drive belt tensioner (6B209) in a clockwise motion to release belt tension.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the engine splash shield.
  1. Remove the drive belt from the accessory drive belt routing pulley (6C348) and then the remaining accessory pulleys.
Installation
  1. Position the drive belt over the accessory pulleys. Raise and support the vehicle if necessary; refer to Section 100-02 .
  1. Install the engine splash shield.
  1. Rotate the drive belt tensioner in a clockwise motion.
  1. Slip the drive belt under the belt idler pulley (8678) and release the tool. Remove the tool from the drive belt tensioner.
  1. Accessory Drive-With A/C
  1. Accessory Drive-Without A/C
Belt -2.0L Zetec Removal
  1. Raise the vehicle on a hoist; refer to Section 100-02 .
  1. Use a 13 mm wrench to rotate the drive belt tensioner (6B209) in a clockwise motion.
  1. Remove the drive belt (8620).
Installation
  1. Position the drive belt on all the pulleys and the drive belt tensioner.
Item Part Number Description 1 10300 Generator 2 19A216 Drive Belt Idler Pulley 3 3D673 Power Steering Pump Pulley 4 8509 Water Pump Pulley 5 6B209 Drive Belt Tensioner 6 19703 A/C Compressor 7 6316 Crankshaft 8 19A216 Drive Belt Idler Pulley 9 8620 Accessory Drive Belt
  1. Install the drive belt and gently release the drive belt tensioner.
    • Run the engine for several minutes to seat the belt into the pulley grooves.
Jul 09, 2011 | Ford Escort Cars & Trucks
How do i loosen the belt to get the alternater off
.whtbtnshow{font-family:;font-size:10pt;font-style:;font-weight:;text-decoration:;color:;}
Accessory Drive Belt Tensioner
Removal & Installation To Remove:
  1. Rotate the accessory drive belt tensioner clockwise.
  2. Remove the accessory drive belt.
  3. Remove the accessory drive belt tensioner bolts.
  4. Remove the accessory drive belt tensioner.
To Install:
  1. Install the accessory drive belt tensioner.
  2. Install the accessory drive belt tensioner bolts. Tighten to 18 ft-lb (25 Nm).
  3. Install the accessory drive belt.
  4. Rotate the accessory drive belt tensioner counterclockwise.
Oct 26, 2009 | 1998 Lincoln Navigator
How do i remove a belt from a 2001 hyundai xg300 car
To install:
Accessory drive belt routing—1.5L engine
Accessory drive belt routing—2.0L engines
Accessory drive belt routing—2.4L engines
Accessory drive belt routing—2.5L and 2.7L engines
Accessory drive belt routing—3.0L and 3.5L engine
Oct 17, 2009 | 2001 Hyundai XG300
How do I change the timing belt on a 2003 Tiburon
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
To install:
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. Accessory drive belt routing-2.5L and 2.7L engines
Fig. Accessory drive belt routing-2.4L engines
Fig. Accessory drive belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt routing-1.8L and 2.0L engines
I hope help you with this (remember rated this help) Good luck.
Sep 15, 2009 | Hyundai Tiburon Cars & Trucks
How to change 1999 nussan quest ac belt
http://groups.yahoo.com/group/villagerquest/
Belt —A/C Removal
  1. Remove the A/C compressor drive belt.
    1. Loosen the A/C compressor drive belt pulley tensioner bolt.
    1. Loosen the A/C compressor drive belt idler pulley adjustment bolt.
40f6b66.gifInstallation
  1. sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Incorrect drive belt installation will cause drive belt failure.
    NOTE: Inspect the pulleys for warping or abnormal wear.
    NOTE: Make sure drive belt is properly installed on each pulley.
    To install, reverse the removal procedure.
    • Adjust the A/C compressor drive belt. For additional information, refer to Belt Adjustment—A/C .
Aug 10, 2009 | 1995 Nissan Quest
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Replacing the tension belts on the reFord windstar 1998.
FOR COMPLETE Diagram Of this Procedure and Belt Routing Email Me@rejakwilsoon@aol.com and I will Send DETAILED PICTURE and Instructions
NOTE:
  • Minor cracks in the V-grooved portion of the serpentine drive belt are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
  • When installing drive belts on pulley, make sure that all V-grooves make proper contact with accessory pulleys.
Conditions requiring drive belt replacement are excessive wear, rib chunkout, severe glazing, frayed cords, etc. Replace any drive belt that exhibits any of these conditions.
REMOVAL
  1. Using a 15 mm socket or wrench attached on drive belt tensioner pulley bolt. Rotate drive belt tensioner clockwise to remove drive belt from pulleys. WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP.
INSTALLATION
  1. Install drive belt over all accessory pulleys (except drive belt tensioner).Rotate drive belt tensioner as described under Removal to install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys
Feb 10, 2009 | 1998 Ford Windstar
Garden Logo
51 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
