Question about Zenith ZHX-313 System
VCR has sound, but no picture
My vcr has sound but no picture. I just get a blue screen that says "Zenith" The dvd's play fine, but the video's won't play anything but sound.
  • aevalouise Mar 18, 2008
    Help! I have the exact problem.
  • lindsey_gill Jan 07, 2009
    exactly what it say.....no picture only sound.
snakehead
  • 1074 Answers
SOURCE: Some sound missing from DVD playback
plug out your dvd for about 2hrs and plug it in back then start all over.good luck.
Posted on Apr 01, 2007
SOURCE: Zenith XBS444 shuts off
the problem is the fan and shutts off
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: VCR sound works but no picture
It could be that the video heads are just clogged.
Get a known good video tape and put it in the unit and let it just play and play and play. Quality video tapes have head cleaning substances built into the tape. If this does not work, get a Scotch Black Watch tape head cleaner. If that does not work the the heads are bad or some other problem.
Posted on Apr 23, 2009
  • 19 Answers
SOURCE: I have a Zenith DVD/VCR and I am recording a tape
unless the security camera has a setting for recording the date stamp you probably can't. The camera probably has a setup tab to enable embedding the date stamp on the video.
Posted on Nov 14, 2009
mybradley7
  • 242 Answers
SOURCE: zenith zhx313 theatre system...vcr accepts tape, but won't play..
retime the gears.
Posted on Jul 18, 2010
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
Magnavox dvd recorder/vcr
It sounds like you may have your vcr connected via composite cable. Check the back of your VCR and follow the cable to your TV. You should see a Red, White and Yellow connection on both ends. The Yellow connector is the video.
Here is an image to help you find it:
Feb 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can not get picture when vhs is playing
This a typical symptom of a dirty video head. People get confused because there is no sound. You see most of all VCR's are designed to mute the sound till the picture is OK. So as soon as you clean the video head using a cleaning tape and get a good picture on the screen you won't get any sound.
Jul 06, 2011 | Philips Magnavox DVD/VCR Dual Player
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Jan 07, 2009 | Zenith ZHX-313 System
Magnavox mwd2205 - VCR Function
grace0308, Many of the combo units have multiple video outputs and some, like the SVHS and RGB Component outputs, are for DVD only. Make sure that you are plugged into the proper video output. Play a tape and try them all.
Mar 08, 2008 | Philips Magnavox DVD/VCR Dual Player
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
Apr 01, 2007 | Zenith ZHX-313 System
Zenith ZHX-313 System Logo
494 people viewed this question
Top Zenith Audio Players & Recorders Experts
Marvin
Marvin
xalint1
xalint1
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
