Recording Error on Funai DRV-B2737
When I insert a new disk it comes up with the following error when trying to record or format -
Recording Error - Unable to record on tis disc - E4 5037380
  • jondoh Mar 25, 2008
    Have Funai DRV B2737 have only ever managed to record one show onto DVD now cannot format any discs. Have cleaned optic and all discs play.
    Blank disc loads but Error message is E54043E02 when trying to format
    many thanks
    john
  • PeteandPat Feb 28, 2009
    When I insert a new disk it comes up with the following error when i am trying to record or format -
    Recording Error - Unable to record on this disc - E4 54037380
    it still works ok on old dvds???
5 Suggested Answers
SOURCE: Funai DRV-B2737 Error message
Try using old-fashioned 2x DVD-RW discs, eg the cheap ones from Datawrite.
This seems to work in my machine MOST of the time.
Posted on Sep 12, 2008
ginko
  • 19396 Answers
SOURCE: funai dvd/vcr combo B2735
Try cleaning lens first.
Posted on Oct 11, 2008
var-pun
  • 331 Answers
i think there must be a daulty with the ...disk
because that has a bigger probability........
teqman
  • 75 Answers
I'd had this problem with my 2737 for quite some time but haven't had the time to fix this until now.
Just for the record it has one laser unit inside which fires off two frequencies one for read the other for write. Anyway, I've been repairing Playstation 1 and 2 and Xbox for years and the most common problem seem to be disc read errors caused by seemingly failing lasers or scratched/damaged discs.
The manufacturer sets these lasers at safe usable limits but after some use they start malfunctioning.
I wanted to copy a VHS recorded disc to my PC tonight only to find I hadn't finalised it in my Funai.
Realising I couldn't because of the silly E4 54037380 error I finally took the plunge and dismantled the unit.
NOTE: the following is not for the faint hearted and please use an antistatic wrist strap to earth yourself.
The Disc tray mechanism has to be removed and a small circuit board directly to the right has too be released. There are a plethora of ribbon cables but only one needs disconnection. Carefully turn the disc drive mechanism on it's back and un clip the thick ribbon cable that attaches to the laser. Tuck the cable out of the way being careful not to damage it. Move the lens unit to the top of the tray mechanism and note there are two potetiometers Using a pot tool or fine flat bladed screwdriver adjust the lower pot by an eigth of a turn (this increases the frequency of the recording laser enough to eliminate the E4 54037380 error completely or it did in my case).Problem solved fully working recorder.
Dismantling procedure
Disconnect Funai from mains and remove the top casing (5 screws)
There are 4 screws holding disc drive mechanism in front right most tricky (use grabber tool to retrieve screw)
Top right has an earth cable connected to it
The other end of the earth cable is held in by another screw on the circuit board next to the drive mechanism this also needs removing
The screw directly below this with the metal earth case strip remove.
The board is held on by two small plastic lugs which need compressing so the board can pop up.
Remove drive mechanism carefully along with the circuit board and flip the whole lot over. Be mindful of the ribbon cables as they are fragile
Posted on Jun 23, 2009
Why doesn't my recorded dvd-r movies play on my magnavox dvd player
Does your DVD player support that version of DVD disk? Not all players will handle DVD-R. Check the manual for compatibility.
Try recording to DVD+R then see if your player will play it.
Also, in what format (.avi, .flv, .mov, etc.) was the item recorded and is your player able to handle that format? Again, check the manual for compatibility.
Jan 20, 2015 | Funai FDRV90E DVD Recorder/VCR
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Where can I get a replacement DVD deck for the DRV-B2737.
It will cost more than the deck did by the time you get done
Aug 17, 2010 | Funai PY90DG DVD Recorder
Funai DR-B2737 DVD recorder wont record
use mr dvd discs-dvdr youcan buy at poundland they are the only discs that seem to work
Mar 25, 2009 | Sony Ericsson w580i Cellular Phone
DECODE ZONE
CAN YOU TELL ME HOW TO CHANGE THE REGIONAL CODE ON MY FUNAI DCVR 7530D USING THE REMOTE
Dec 01, 2007 | Funai FDRV90E DVD Recorder/VCR
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
