Question about Bosch Classixx WFL 2066 Front Load Washer
Electrics not working and its not the fuse in the plug. Where is the fuse on the machine?
  • Bosch Master
  • 3,463 Answers
There is no fuse ftted to these washers.
Try it another socket and make sure you have fitted a fuse that you know is good, also check cable for breaks in insulation.
Hope this helps.
Posted on Dec 12, 2009
Hi just wondering Where do i locate fuse in my 2015 samsung 6.5 kg top loader washing machine.. thanks
did not know they had fuse. if possible only use recepticale for washer. unplug washing machine and check your electrical source. plug in someting else in the washer's wall receptacle. if not working reset breaker or replace fuse at main house's electrical panel.. be responsible, no wet hands etc.
if receptacle is ok, plug in washer and look for any indication that electricity is coming into machine, perhaps a light or similar. your lid locking switch may have failed or has become loose. if timer is set by twisting and makes
clicking sound, your timer may have been at end of a
previous wash. if your timer is electronic, there may be
a fuse on one of your machine's computer boards. please
check your owner's manual.
Mar 03, 2018 | Samsung Washing Machines
My washing machine has no power to it
Could have blown a circuit breaker in your electrical panel and if you have fuses could blow a fuse. You may have a short some place. Start with checking the cord and the plug its self. If you have a GFI receptacle you may have to reset that as well
Aug 30, 2016 | Washing Machines
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
My Imperia electric pasta machine in not getting power?
I would doubt that it's the electrical cord or plug, (though anything is possible.). I don't know this machine that well. It's possible that the switch is bad, but more likely I would think that it might be a fuse inside the machine.
Did it stop working while making pasta? Or was it working fine the last time, you put it away, brought it back out and now it's dead? Or is it a machine you bought new and it's DOA?
If it was overworked, it may have overheated and blew a fuse inside to protect the motor or other parts from burning up.
You might want to bring it to a local appliance repair shop that can take it apart to test things out to see were the disconnect is.
Jan 26, 2015 | Imperia Pasta Presto Electric Pasta...
When in use it blows our fuse
The manufacturer of this product does not provide electrical ratings or requirements in the manual.It looks to be a small commercial type, but seems to available for purchase at many home appliance / small electrics departments in mainstream stores. Check the electrical rating of the machine.. it should be on a tag or label near the cord. If the machine is rated 1440 watts or less, it can be connected to a 15 amp circuit. If more than 1440 but less than 1920, it will require a 20 amp circuit.
If it has a standard plug, it should work in a standard kitchen counter outlet. A standard kitchen counter outlet in North America is rated for 120 volts / 20 amps. I would suspect that this appliance requires a fairly large amount of power for a short period of time, so it may be similar to a toaster or coffeemaker. That means it would need at least 12 amps itself. If you are trying to use this machine while another appliance is on / running on the same circuit - it is very likely that the fuse or circuit breaker would open. When the fuse does open - it should be replaced with a fuse of the same amp rating - never increased. If there are other devices that shut off because of the fuse opening when using this machine, disconnect them at the outlets. Shut off lights that go out, too.
Replace the fuse and try to use the machine. If it works, your problem is that there is too much on at the same time. You'll need to find a different circuit to plug the machine into that has little other load when the machine is in use, or rearrange the other devices so that this machine can be plugged in where you want it. The last resort would be to call an electrician to either add a new circuit or two or, split up the existing circuits so that they will have more capacity. If it doesn't work, you'll need to test some more by locating a circuit that has little or no load on it already - a circuit with only one plug on it is ideal, but can be hard to find. Once you're sure that everything on the circuit is unplugged / shut off, try again. If it still fails - it's likely that something is wrong with the machine.
I hope this helps and good luck!
Aug 28, 2011 | Breville BES830XL
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Not working
You most likely destroyed the pump. But if you are lucky, you can open the unit and look for a fuse. It will be on the circuit board in the unit or possibly in line with the power wire. It will be a thermal fuse that is wrapped in a teflon mesh cover. If there is no fuse, then chances are the unit will be a loss unless you know someone handy in electronics.
Oct 20, 2008 | Karcher K2.26 Electric Power Washer
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
178 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
