Question about Microsoft Windows XP Professional
Access denied to documents and settings folder
Windows crashed, used XP disk to da a "Repair windows installation", windows now works and boots up , but cant access my old account whch was not password protected... In other words when trying to access "Documents and settings\(Account name)\my documents" it gives me "Access Denied" message... when trying to gain access through M.S Dos command prompt it also says "Cant't access specified folder make sure file is not write or copy protected"... I Really need to access that folder seeing that there is alot of photos of my famiy and files that I was clever enough to not have made a backup of.. Please help if possible
  • naudenico44 Dec 12, 2009
    Yes the account I'm trying to access is an admin account without a password and the account I'm trying to access it form is also an admin account in another name... If I go to the account using win explorer and right click select properties it tells me the folder is 0bytes or empty, atttributes : Read only, but if I use the Repair console from the XP installation disk it throws me to an operating system similar to M.S.Dos... If I then go into the directory I can see that the files and folders are there and copy the files one by one which is extremely time consuming and tiring having to tipe in the different commands...
    Any Suggestions?
  • 1,511 Answers
The account that you are accessing; is it an Admin account, and now from the very account you are trying to access that account is a limited one, Is that so?
If that is the scenario, then there are ways through which you can get an admin access, but IF those files aren't there or are corrupted, then that is something else.
I'm waiting for your response...
Also get the properties of that account folder and tell me that folder size, to have an idea that is there something in it.
Regards, WAQAR.
Posted on Dec 12, 2009
  • Waqar Hassan
    Waqar Hassan Dec 12, 2009
    Actually you are trying to access a folder that was created by another account. Since you have not repaired your Windows Installation, you cannot login to that account. But no need to worry, Yes, you can easily access all those files.
    You need to take ownership of that folder you want to access. The access is denied message is actually showing up because of NTFS security restrictions.
    Here is all you need to know to get ownership:
    Log on as an administrator
    If you have Windows Xp Home Edition, Start Windows XP Home Edition in safe mode
    Disable Simple File Sharing in Windows XP Professional
    To disable simple file sharing yourself, follow these steps:
    1. Click Start, and then click My Computer.
    2. On the Tools menu, click Folder Options.
    3. Click the View tab.
    4. In the Advanced Settings section, click to clear the Use simple file sharing (Recommended) check box.
    5. Click OK.
    To take ownership of a folder
    To take ownership of a folder, follow these steps:
    1. Right-click the folder that you want to take ownership of, and then click Properties.
    2. Click the Security tab, and then click OK on the Security message (if one appears).
    3. Click Advanced, and then click the Owner tab.
    4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of the folder, select the Replace owner on subcontainers and objectscheck box.
    5. Click OK, and then click Yes when you receive the following message:
      You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?All permissions will be replaced if you click Yes.
      Note folder name is the name of the folder that you want to take ownership of.
    6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
    I am sure this will solve your problem. If it does please do rate my solution. If you are still having any problem, comment here.
    You can also refer to these:
    http://support.microsoft.com/kb/308421
    http://support.microsoft.com/kb/307874/
    http://support.microsoft.com/kb/308419
    Regards,
    Waqar.
SOURCE:
I have a windows 7 ultimate, but i want to change it to windows xp service pack 2. can i change windows 7 to win xp without damaging all the data i have stored?
YES BUT FIRST YOU HAVE TO WIPE THE HARD DRIVE. YOU CANNOT "DOWNGRADE" FROM 7 TO XP...ONLY UPGRADE.
BACK UP ALL DATA FIRST
Oct 15, 2010 | Microsoft Computers & Internet
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
Tip
How to do System Restore when the computer doesn't even boot to Safe Mode in...
System Restore is assumed to be the best method to recover the system from Registry or System file errors. Its easy to perform and is effective, no doubt. But what happens when the system doesn't even boot to the desktop, neither in Normal mode, nor in Safe Mode. How do you do a System Restore then. For Vista and Win 7 users, its a piece of cake, since the WinRE provides them the direct option to System Restore from the installation/repair CD. But what for the XP users?
The following method is very useful and serves as a bliss for Windows XP users to recover their system from crashes due to Registry or System file failures. All you need for the method is a Windows XP installation CD. (This is not a re-installation process. All data and settings are intact after the operation.)
Step 1: Boot to the Recovery Console
  • Insert the Windows XP CD into the computer.
  • Turn the computer off.
  • Setup the computer to boot from cd: either by pressing F2, F9 or Delete to go in BIOS and changing the boot sequence or by pressing F12 on Dell computers to launch the Boot Device Menu.
  • As soon as you get the message 'Press any key to boot from the cd', hit enter.
  • Wait for the Windows Setup to initialize
  • At the Welcome to Setup screen press R to repair windows using recovery console.
  • You will be prompted to choose a Windows installation. Press 1 on the top of the keyboard and then press Enter.
  • You will be prompted to enter the Administrator password. Press Enter if no password was set.
Step 2: Accessing the Restore points.
Type the following commands in the Recovery Console.
cd system~1
If you get an Access Denied error:
  • Type the following commands to change the directory to c:windowssystem32config:
    cd windows
    cd system32
    cd config
  • Rename the system branch of the registry. That will allow us to access the system restore folder from inside the Recovery Console. In case the process fails and you want to perform a Windows Repair you will need to rename system.bak to system again.
    ren system system.bak
  • Type exit to leave the recovery console and to restart the computer.
  • Go back into the Recovery Console and repeat Step 2.
cd _resto~1
If the _resto~1 folder exists, inside it there are several folders named RP1, RP2. These are restore points. RP1 is the oldest restore point. You can use dir to view what RP folders are available. If there is no _resto~1 folder or if there are no restore points inside it:
  • Type the following commands:
    cd
    cd windows
    cd system32
    cd config
    copy c:\windows\repair\system system
  • If you are getting a file not found error try:
    copy c:\windows\repair\system.bak system
  • Then type the following :
  • copy c:\windows\repair\security security
  • copy c:\windows\repair\software software
  • copy c:\windows\repair\sam sam
  • copy c:\windows\repair\default default
  • exit
  • You will be able to boot into a altered version of the operating system. Backup your files from the c:Documents and Settings folder and then reinstall the operating system.
Step 3: Choose the most convenient RP folder.
Supposing we have RP3 available let's type in:
cd rp3
Change the directory to snapshot:
cd snapshot
Step 4: Restore the main registry branches.
If you are being asked if you want to overwrite type in y to agree.
copy _registry_machine_system c:\windows\system32\config\system
copy _registry_machine_software c:\windows\system32\config\software
The following commands are most of the time optional however the process might not work if they are not executed
copy _registry_machine_security c:\windows\system32\config\security
copy _registry_machine_sam c:\windows\system32\config\sam
copy _registry_user_.default c:\windows\system32\config\default
Type exit to reboot the system. Start the computer normally.
Thanks,
Abhishek
on Mar 22, 2010 | Microsoft Windows XP Professional
When my laptop is turned on, it shows, We apologize for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped...
You have corrupt or deleted windows files or possibly a hardware error. The first thing is to try a repair using a Windows XP CD that came with your system.
XP REPAIR INSTALL 1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS. Check your system documentation for steps to access the BIOS and change the boot order. 2. When you see the "Welcome To Setup" screen, you will see the options below. This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER.
  • To repair a Windows XP installation using Recovery Console, press R.
  • To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup: do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R". 4. Accept the License Agreement and Windows will search for existing Windows installations. 5. Select the XP installation you want to repair from the list and press R to start the repair. 6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. 7. You will need to apply Windows updates after this procedure.
Sep 21, 2010 | Dell Inspiron 1545 Notebook
My windows crashed after surfing the net. It started with a certain file: wmisrdp.exe want to do a download in a hidden way as told to me by my anti virus.. Even after clicking on TERMINATE, Quarantine it...
Click start menu then click search. After that when the search wizard is displayed, click all files and documents with that green arrow. When you click that, drive will appear below then choose, drive you want to search. when that runs normally with the search, try to open on My computer then click second partition hard drive to access to your files and folders.
Thanks.
Dec 12, 2009 | Microsoft Windows XP Professional
How can i get in to my windows xp i lost/forgot my password. cd-rom is not working
Install a working CD-ROM drive.
Put your Windows XP disk into the CD-ROM drive.
Boot the computer from the CD-drive.
If you are very careful, and read the installation questions carefully,
and respond accurately, you can install another copy of Windows
onto the 'C:' drive, AND CHOOSE A FOLDER NAME THAT IS *NOT* 'C:\WINDOWS'.
Eventually, you can copy all your files from your "old" MY DOCUMENTS folder to your "new" MY DOCUMENTS folder.
Sep 11, 2009 | Microsoft Windows XP Home Edition
I CAN'T INSTALL A WINDOWS XP SOFTWARE
Thank you for choosing Fixya.com
Yes you can install the Windows XP on P4X266.
Here could be five various steps you can go about.
  • Method 1: Perform a clean install of Windows XP
    Use this method for a clean installation of Windows XP. A clean installation removes all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk.
  • Method 2: Upgrade to Windows XP
    Use this method if you are upgrading to Windows XP from Microsoft Windows 98, Microsoft Windows Millennium Edition, or Microsoft Windows 2000 Professional.
  • Method 3: Install Windows XP to a new hard disk
    Use this method to install Windows XP to a new hard disk. This is typically done when a new hard disk is installed on your computer.
  • Method 4: Install Windows XP to a new folder (parallel installation)
    Use this method to install Windows XP to a new folder (parallel installation) to either run two operating systems, or to access, repair, or retrieve data from a damaged disk.
  • Method 5: Perform a multiple boot operation
    Use this method to install Windows XP as a separate operating system on your computer. This lets you install more than one operating system on your computer and select which operating system that you want to use every time that you start your computer.
To check the detailed information, check this Microsoft Knowledge Base Article.
http://support.microsoft.com/kb/316941
Hope this would help !!
Regard's
Anurag Shukla
Sep 08, 2009 | VIA P4X266 PE11-L Motherboard
Missing or corrupt hal.dll file, so can't boot the hard drive
Hey,
Please use the recovery discs or windows installation cd.
To either perform a full system restore with the recovery discs.
Or to perform a repair installation with the windows installation cd.
Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Thanks and good luck.
Ekse
May 03, 2009 | Dell Dimension 3100 PC Desktop
Repairing Damaged Winsock2
  options below This portion of the Setup program prepares Microsoft
  3. Press Enter to start the Windows Setup.
  read this Warning!!
  Blaster worm warning: Do not immediately activate over the internet
  when asked, enable the XP firewall
  [ http://support.microsoft.com/?kbid=283673 ]
  before connecting to the internet. You can activate after the
  firewall is enabled. Control Panel - Network Connections. Right click
  the connection you use, Properties, and there is a check box on the
  Advanced [ http://michaelstevenstech.com/xpfirewall1.jpg ] page.
  7. Reapply updates or service packs applied since initial Windows XP
  installation. Please note that a Repair Install from the Original
  install XP CD will remove SP1/SP2 and service packs will need to be
  reapplied.
  Service Pack 2
  http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-
  4F30-8245-9E368D3CDB5A&displaylang=en
  An option I highly recommend is creating a Slipstreamed XP CD with SP2.
  Slipstreaming Windows XP with Service Pack 2 (SP2)
  http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp
  ______________________________________________________________________
  Warning!!
  If the option to Repair Install is not available and you continue
  with the install;you will delete your Windows folder and Documents
  and Settings folder. All applications that place keys in the registry
  will need to be re-installed. You should exit setup if the repair
  option is not available and consider other options.
  Try the link below if the repair option is not available.
  Windows XP Crashed?
  http://www.digitalwebcast.com/2002/03_mar/tutorials/cw_boot_toot.htm
  Here's Help.
  A salvage mission into the depths of Windows XP, explained by a
  non-geek
  by Charlie White
  Related links
  You May Lose Data or Program Settings After Reinstalling, Repairing,
  or Upgrading Windows XP (Q312369)
  http://support.microsoft.com/default.aspx?scid=kb;en-us;Q312369
  System Restore "Restore Points" Are Missing or Deleted (Q301224)
  http://support.microsoft.com/default.aspx?scid=kb;en-us;Q301224
  How to Perform an In-Place Upgrade (Reinstallation) of Windows XP
  (Q315341)
  http://support.microsoft.com/search/preview.aspx?scid=kb;en-us;Q315341
  Warning!! If the Repair Option is not Available
  What should I do? Most important do not ignore the information below!
  If the option to Repair Install is NOT available and you continue
  with the install; you will delete your Windows folder, Documents and
  Settings folders. All Applications that place keys in the registry
  You should exit setup if the repair option is not available and
  consider other options. I have found if the Repair option is not
  available, XP is usually not repairable and will require a Clean
  install.http://michaelstevenstech.com/cleanxpinstall.html
  If you still have the ability to access the Windows XP installation,
  backup all important files not restorable from other sources before
  attempting any recovery console trouble shooting attempts.
  Possible Fix by reconfiguring boot.ini using Recovery Console.
  1.Boot with XP CD or 6 floppy boot disk set.
  2. Press R to load the Recovery Console.
  3. Type bootcfg.
  4. This should fix any boot.ini errors causing setup not to see the
  XP OS install.
  5. Try the repair install.
  One more suggestion from MVP Alex Nichol
  "Reboot, this time taking the immediate R option, and if the CD
  letter is say K: give these commands
  COPY K:\i386\ntldr C:\
  COPY K:\i386\ntdetect.com C:\
  (two other files needed - just in case)
  1. Type: ATTRIB -H -R -S C:\boot.ini DEL C:\boot.ini
  2. Type: BootCfg /Rebuild
  which will get rid of any damaged boot.ini, search the disk for
  systems and make a new one. This might even result in a damaged
  windows reappearing; but gives another chance of getting at the
  repair"
Oct 20, 2008 | Computers & Internet
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
Microsoft Windows XP Professional Logo
530 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
