Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD external HD doesn't show on vista in my computer or drive mana
Hi I have a wd external HD on a vista pc that worked initially,and i stored some files on it. I didn't use it for a while and now i plug it in and it detects new hardware but can't find drivers to install. doesn't show on my computer or drive management. i took it to best buy and they plugged it into theirs and it worked.Not sure what to do. thanks
    Guru:
  • 1,738 Answers
You could have a virus on your computer. Do a virus scan by going to nortan's website. There is no way around the virus, the only way is to format the drive, and reload windows.
Posted on Dec 12, 2009
External hard disk
You should not need a disk to get an external hard disk initialized. Did you try to plug it into your PC and see if it detects it?
Sep 09, 2013 | Verbatim 1TB PRTBL USB 12.5MM-3.0 2.5...
How do I use my WD hard drive to store files so I can free up space on my laptop hard drive?
Hi:
That's an easy task:
1) Plug your Hd to your laptop and wait until the laptop recognize it as a new drive and assign a new letter to it. If you have a disc use it if your laptop ask for it.
2) Copy all files you want to transfer to the new HD and paste them on it.
That's it.
Sep 27, 2011 | Western Digital WD My Book Essential 1TB,...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
WD Eliments 1T external HD. hidden data
hi there could be a couple of things you can try, you could, ( if you have xp ) have the drive in, then go to my computer, then tools, then folder options, click, view, then look down the list for show hidden files and folders, that's one, the other is to take the drive caddy apart, remove the hard drive ( as they are just normal hdd's in external boxes ) connect it up to a spare port on your desktop computer and see if you can transfer files that way, ( note! this will void the warranty on the drive case if you do this if it is still under warranty ) the other way would be to get a data recovery program, like winundelete, which you should be able to find on either your computer or the net for free, hope this will help
Apr 05, 2010 | Western Digital Elements powered by WD 320...
WD External hard disk fails !!!!?
Most of the front side USB extensions will experience power surges if it was incorrectly connected within the cabinet. So try connecting it to backside of your cabinet directly to your motherboard. If still the problem exists, check for proper ground connection to your electrical outlet.
Aug 03, 2009 | Western Digital (WD2500JBRT) 250 GB Hard...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
Mar 26, 2009 | Western Digital External USB 2.0 80 GB...
Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Nov 17, 2008 | Computers & Internet
Windows xp to vista external HD transfer problem?
It is exactly right... YOU are not 'in control' of the hard drive and your buddy's computer doesnt have the 'permissions' to work with YOUR files...
It MAY be possible to get the okay if he logs into his computer as the administrator.... it is NOT an actual 'hardware' issue... being able to see the files says that... XP and vista are 'close enuf' design-wise that drive compatability isnt it either...
If your friend can log in as 'administrator' he will likely be able to take 'ownership' of the files on your 'external' drive and get what you need!
Aug 18, 2008 | Dynex DX-EF101 (DXEF101) External Floppy...
Install screen and drive won't boot up anymore
Hi Doug,
The problem is that mac has a diffrent 0perating system to a pc the thing you doing by switching from mac to pc the external hard drive is conflicting with one another to make your external driver to work on your pc follow these steps. go into control panal,system,hardware,device manager,universal serial bus controllers,drivers then update drivers that should reconise your mass storage driver.
Jan 16, 2008 | Computers & Internet
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
275 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
