Question about GE JVM1441 Microwave Oven
Appears to work fine but will not heat - GE JVM1441 Microwave Oven
  • 464 Answers
Depending on the age of the microwave, your magnetron might be burned out. This is the component that heats and most models have a 3 - 5 year warranty on this part. Check your instruction manual. If it is not still under warranty, then it is too costly to repair with the prices of microwaves coming down.
Posted on Dec 12, 2009
Testimonial: "thank you"
SOURCE:
Sparks from wave guide
the magnetron may have burnt itself up. it may be time to replace
Nov 05, 2013 | Microwave Ovens
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MY MICROWAVE IS NOT HEATING , EVERYTHING APPEARS TO BE WORKING FINE? WHAT COULD IT BE? IT IS A DAWOOD KOR-1B4H
MY MICROWAVE IS NOT HEATING , EVERYTHING APPEARS TO BE WORKING FINE? WHAT COULD IT BE? IT IS A DAWOOD KOR-131G
Apr 12, 2010 | Daewoo KOR-1B4H Microwave Oven
Unit will not heat up
check contact points for current. tabs might be bent and are not contacting correctly and no heat the Ni-Chrome wire heats up glow orange when currant is applied , might need a test voltage Meter and screw driver too >^.^<
Mar 14, 2010 | Kenmore Microwave Ovens
No heat - everything else works
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 26, 2009 | GE JVM1440 Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Oct 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1441 Microwave Oven Logo
164 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
