Question about Gateway FPD2275W LCD Monitor
Fx70 pavilion 15
I can leave the computer on or turn off for a few minutes.When I turn on the
monitor either way it blanks out for about 5 to 10 minutes then starts working normal. p.s. the colors are ok.
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
My screen just went pink. HP pavilion fx70. Is there a life span for this monitor ? Thank you Donna F.
Might be just a loose cable. Double check if the cables are connected properly. Try to plug and unplug.
Feb 24, 2011 | HP Pavilion FX70 Monitor
My HP Pavilion M90 monitor won't turn on. Every time I press the on button I hear a clicking sound from the back of the monitor. It sounds like it's trying to power up but it doesn't do anything. Is there...
Do a hard reset on the laptop by removing all cords and connections from the computer, including the power cord. Turn the computer over and slide the tab next to the battery, then lift the battery out of its compartment.
Eject any SD cards currently inserted in the SD card slot by pressing on them, then remove them from the slot completely. Hold the computer's "Power" button down for at least 15 seconds, then plug the power cord into the computer and turn it on.
Watch to see if the LED lights near the "Caps Lock" and "Num Lock" illuminate. If the lights do not turn on and the computer's screen remains blank, inspect the power cord and AC adapter for damage and replace them if necessary.
Leave the power cord plugged into the computer and snap the battery back into its slot. Allow the computer to sit for at least 30 minutes, then unplug the power cord and press the "Power" button again to see if the computer will turn on.
Plug the power cord back into the computer and try to turn it on again. If the computer turns on, replace the battery with a new one. If the computer still does not turn on, take the computer to a repair shop.
Oct 04, 2010 | HP Pavilion M90 Monitor
I have an hp pavilion 1503 monitor and it blacks out after a few seconds after turning it on.
Open your monitor up and look for 4 coils on the circuit board. Re solder these coils to the board and it should work fine.
Oct 14, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Hp FX 70 monitor keeps shutting off
Sounds like the problem is with the switch itself. No real fix for this.
Both these monitors will work with your desktop without any additional software.
Feb 14, 2009 | HP Pavilion FX70 Monitor
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Goes Blank
ok ... i answered your last post as well. is there a reset button on it. the few lcd monitors i've worked on required pressing the far left hand button on the front to reset it.
Feb 09, 2008 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
