Question about Hitachi 43FDX01B TV
I have Hitachi 43" hd rear projection tv - too much red
  • 14 Answers
It's probably either a bad red CRT (the red projection tube) or a shorted (or open) driver transistor on the red CRT driver board. If it's the latter case (bad transistor), it can be fixed. If it's the picture tube, well, it's probably time to go shopping for a new TV.
Do you need more information? Do you want to fix it yourself? Do you have electronics knowledge and experience? If not, call a qualified electronic technician (TV repairman), and he can tell you if it's the picture tube or not.
IF (and only if) you are a competant electronic technician, CAREFULLY check and compare the voltage on the collector of the driver transistor on the 3 CRT boards. (The driver transistor is the large one, possibly connected to a heat sink.) The voltages shoud be somewhere around 140 to 160 volts. If the red one is significantly different from the green and blue ones, then it's probably the transistor. Unplug the set (and wait a bit), and check the transistor with a diode or transistor checker. If it checks bad, then you found a bad transistor. Go to NTE Electronic's website to find a replacement. If it checks OK, then you're probably looking at bad (shorted) red CRT.
Posted on Dec 17, 2009
Is this unit HD ready or do I need a box.
your tv is hd ready but you still need a HD box from your provider.
Aug 14, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi Model # 43FDX11B. Will not power
Mine just developed the same problem.. did you find a solution/fix?
Jul 09, 2009 | Hitachi 43FWX20B 43" Rear Projection...
43UWX10B Hitachi rear projection HD ready TV
Replace Convergence ICs STKs will have Part # on them big black ics For parts 1-800-223-3205 www.electronix.com you have 2 of them replace Both!
Jan 03, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Is my Hitachi Tv model 43FDX10B HD ready?
Probably but this hitachi has no reall HD just simulated, called D3VirtualHD by hitachi. Should work, you can always return the blu-ray if it's not what you expected or ask a good salesman if it's worth, you might try it in store...
cheers
Dec 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Ultrascan hitachi 43" hd tv
Marcus,
What you're describing is convergence and the amps need to be replaced... IK04 and Ik05 are two STK392-110 and Hitachi suggests replacing them with the STK392-150's for greater reliability..
If you're not too capable in electronics this is one to leave for the professionals. But at least you can call around and ask what each shop charges for replacing the convergence amps in this unit...
Hope this helps.
Bill
Nov 14, 2007 | Hitachi 43GX01B 43" Rear Projection...
Hitachi HD projection TV-red and green wave and alignment problem
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Oct 31, 2007 | Hitachi 43GX01B 43" Rear Projection...
43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi
if you can hit it and it does something it's telling me you have a loose connection. or cold solder joint.
Apr 28, 2007 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX01B TV Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
