Question about Hotpoint Microwave Ovens
Micr0wavr will not stare the model is H9G6140R
  • bertbell Dec 12, 2009
    where is the fuse located
  • Hotpoint Master
  • 9,125 Answers
Sorry, but that's not a proper Hotpoint/GE model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your detailed symptoms.
Posted on Dec 13, 2009
How doi re progam my Panasonic counter top from demo mode to ther mode to progam and heat and warm up timed dinner plate and heattimed hot meal or beverage give ne insructions of what to do
A common answer to this for Panasonic microwaves is "4 presses of the Timer On/Off button" toggles Demo on and off.
Without you specific model, I can't be more specific than that.
Dec 25, 2014 | Panasonic Microwave Ovens
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Why won't my Kenmore elite micro work?
Need more info. Is anything working or is it completely dead? Does it sound like it's working, but it's just not heating? Or does it just sit there and stare at you when you press the START button? Really need more info.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 12, 2014 | Kenmore Microwave Ovens
Cplmv169dc
see this steps and fix it. God bless you
First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Magnetron what is problem?
However see the table for test it.
Oct 04, 2012 | Electrolux Microwave Ovens
I have a Microwave GE make, Model No. JES1238WH001, made in Malaysia, in July 2003. On staring this, in the panel, "PF" appears for few seconds and then "F3" appears and no further...
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault. Spares can be aquired through your GE dealer. Visit GE's web site for a list of dealers and spare parts suppliers.
Hope this helps.
Nov 27, 2010 | GE Microwave Ovens
My GE Advantium model SCA1000HBB01 was cooking on the oven setting and suddenly quit working. As if no power. The circuit is still good. I was advised it was possibly a blown fuse inside the MV on the...
When you take the top off and stare into the unit you will see a white fuse in a black plastic fuse holder. Look carefully. I had to replace the melted fuse holder as well. Radio shack has the fuses and holders.
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Key pad not responding SHARP R-9H11
Without being able to put my meter on it. My first guess is that you have a bad board. I would say a high limit but it either works or don't work. It does not come and go. There is not a lot to a microwave. You have door switch's, Mag tub, fuse, fan, transformer, diodes, belt, high limit, pc board and a touch pad. This sounds like a pc board to me. Honestly, if it's not a fuse. Unless it's a high dollar built-in unit, they are not Worth fixing. You can buy a new one cheaper. This is why a lot of service company's don't work on them anymore.
Please rate this solution if helpful.
Aug 21, 2009 | LG LMVM1935 Convection/Microwave Oven
Microwave oven continue to blow Cerimic fuse?
it sounds like you either have a faulty switch or a faulty bulb as this is on an unprotected circuit if has blown it will create a short.if the problem is happening when the machine is being stared it will be either a magnetron fault,capacitor shorted or a diode shorted .to check these you will need a multimeter that has a 10 k scale with a 9 volt battery inside,hope this helps regards les
Aug 01, 2008 | Panasonic Microwave Ovens
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Jerry Greenberg
Jerry Greenberg
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
