Question about Jabra BT500 Wireless Headset
Can't get BT500 to go to solid blue light for pairing.
  • 103 Answers
You have to hold for three seconds
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Posted on Dec 12, 2009
  • Scott Ferguson
    Scott Ferguson Dec 12, 2009
    fisrt charge it fully
I'm trying to pair my jabra bt500 with my iPhone 4. I get all the way through the process when I receive the following message: Connection Unsuccessful "Jabra BT500" is not...
I just had this same problem. I solved it by turning the iPhone Bluetooth off and then back on, after which the pairing (with passcode 0000) worked properly and so does the headset.
Dec 28, 2010 | Cell Phones
Hello. I can't seem to get my phone to "discover" my bluetooth device.... Help?
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT500.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank You
Sep 05, 2010 | Jabra BT500 Wireless Headset
I can't get my H710 to go into pairing mode... solid blue
First, if you've already paired it with another phone, make sure that phone is turned off. Close the headset and wait a few seconds, then reopen it by flipping out the boom (mouthpiece).
If that doesn't work, try this adapted method from the H700 model: Press the multi-function (center) button and hold it in until the light turns blue. As soon as you see the blue light, immediately open the boom (mouthpiece). Hopefully it will remain solid blue, indicating you're in pairing mode.
Jan 08, 2010 | Motorola Mobility H710 Bluetooth Headset
Cant par my jabra bt125
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
Jan 15, 2009 | Jabra BT125 Headset
Bluetooth help
When you pair the bluetooth headset default passkey (PIN) should be used as "0000" (4 zeros). for further info you can check the user manual as I attached the link below
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT500/Documents/UM/BT500_UM_NA_EN_480.pdf
Good Luck
Feb 20, 2008 | Jabra BT500 Wireless Headset
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
Not working with Samsung U600
YOu will have to put the headset in pairing mode by keeping the power button pressed till the light becomes solid blue instead of blinking. Now switch on the blue tooth of your mobile and try pairing,. it should work. passcode will be 0000
Jan 29, 2008 | Samsung WEP200 Headset
Jabra bt500
yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
Jan 04, 2008 | Jabra BT500 Wireless Headset
Cant hear
I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
Oct 31, 2007 | Jabra BT500 Wireless Headset
Jabra BT500
the pin number is 0000, press and hold button until the light stays on to pair with your phone.
Jun 04, 2007 | Jabra BT500 Wireless Headset
Jabra BT500 Wireless Headset Logo
213 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
