Question about Whirlpool MH3185XP Microwave Oven
The door no longer shuts properly causing it to stop cooking
  • Whirlpool Master
  • 8,404 Answers
I thnk you have a broken latch or you have a broken catch inside your oven. Please inspect both possibilities. While your oven is oen, consider replacing the dafety interlock switches.
find parts at a FixYa.com partner or advertiser or your local appliance parts place or at www.repairclinic.com
Post comments to this question if you need more information please.
thanks for your interest in FixYa.com
Please vote
thanks
a
Posted on Dec 12, 2009
Sharp combo microwave: Turntable wont stop unless I leave the door ajar. Light stays on too while turntable is going. Everything else works fine - it just doesn't know when to shut up! :)
It's a door switch that's bad. Probably the secondary interlock switch. You need an ohm meter to verify switch not 'making' electrically. Usually the only thing that causes this switch to fail is from opening the door when the microwave is cooking, secondly, by cooking at very extended lengths of time.
Aug 28, 2013 | Sharp Microwave Ovens
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
My microwave will not shut properly. The top latch will not completly close. The microwave still runs... but It will not heat food and it makes a clicking noise. Can this be fixed or should I purchase a...
Hi, quite often this is due to a bad door switch located inside behind the area where the door hooks go into the oven.
Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide for $32.50, but it's usually a door switch.
It can be fixed......
Apr 28, 2011 | Whirlpool MH2155XP Microwave Oven
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
I have the Panasonic "The Genius" 1300 w microwave. I can not get it to work properly. When I push the time to cook then start, the light comes on (no sound from microwave) the timer goes down...
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In this case, it's probably happening because it;'s not cooking due to a switch problem.
Aug 17, 2008 | Panasonic Microwave Ovens
Microwave will not turn off. it runs and runs when door is shut stops when door opens but if you shut the door again it just runs unless i unplug it. It will not heat light is on clock works .will not...
This is usually caused by either a bad door switch or a loose door switch mount, or sometimes a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | Microwave Ovens
I have a LG Microwave oven, model #MV-154SJ. When pressing Time Cook, the Microwave no longer heats. The light comes on like it would start heating but the usual humming sound is no longer there and the...
This is usually caused by either a bad door switch, a loose door switch mount, or a sometimes problem on the control panel.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
Feb 27, 2008 | Microwave Ovens
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Whirlpool MH3185XP Microwave Oven Logo
60 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
