Question about McCulloch Garden
What do i look for when the chainsaw doesn't start
THERE IS NO GAS LEAVING THE CARB AFTER PRIMING THE PUMP OF A PULSON PP4218AVX CHAINSAW. CHANGED THE FUEL LINES AND PUMP. STILL DOESN' T START.
Hi Leo...
Check to make sure you have the fuel lines installed correctly.
Check out the picture below
Please take time to rate me
Bud
Mar 21, 2013 | Garden
Hitachi CS33EB won't start when hot solution?
see if you loosing spark when it doesn't start
Aug 10, 2012 | Hitachi Garden
Will chainsaw run with brake removed
yes it will still run!
it doesn't need brake on to run, hope this helped.
Jul 26, 2012 | Garden
If my chainsaw starts but the chain doesn't
Its more than likley the chain brake has acttivated, grab the hand guard and pull it firmly fully back to the top handle, you should here a click as it loads, now try again
May 26, 2012 | Poulan Garden
Craftmans and mcculloch chainsaws have been sitting 2 years and will not start
Try cleaning or replacing the spark plug, try using a can of small engine starting fluid shot into the carburetor to get it going. If this doesn't work, the gas has probably evaporated and left the carburetor with a coating similar to shellac inside. I would suggest having a small engine repair shop clean/replace the carburetor. If you are able to do this yourself, you should be able to find great prices on parts at www.sepw.com
Aug 31, 2011 | Garden
When i try too start the weedeater it either doesn't start or it acts like it is only firing half the time. Then it dies out.
check your compression on the weedeater needs to a min of 110 psi to run properly..email me with any questions on how to check the compression..whitejeff74@yahoo.com
Jul 25, 2011 | Homelite Garden
My chainsaw was working fine. I cut down a couple of trees. I stopped it and now it will not start. Can you flood a chainsaw. Any help would be appreciated. Tony
yes you can flood them, set the choke and pull the rope a few times, that should clear a flooded motor, if this doesn't correct it, the plug may be fouled, remove it , see if its wet with fuel,, blow it off and try again
Jul 08, 2011 | Garden
Doesn't start has spark @ plug fuel @
try starting meaning pull the rope 6 times and then check the spark plug if its wet clean it or try a new plug, if its dry your not getting fuel in the cylinder which means carb problems. if you have a seringe or something to put some gas into the spark plug hole then install spark plug and try it. if it runs for a couple of seconds then you need to focus on the carb. only put a small amount of fuel in the plug hole if you try it otherwise youll be pulling on the rope for awhile before it will start. hope this helps.
Jul 06, 2011 | Echo CS400 18" Chain Saw
Chainsaw doesn t start because is cold
give it a shot of starting fluid and see what happens , should start
Feb 02, 2009 | Garden
Garden Logo
59 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
