Question about Batteries.com Cameras
Camera battery charger(1 hour charger) item#ch-4920 when batteries are placed in the unit the red light only flashes for approx two minutes and the battery is not fully charged... this is the second unit we've tried... can you help?
  • 24,418 Answers
Batterries dot com are a good company and I would suspect that the battery is at fault, not the charger.
Posted on Dec 12, 2009
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Dec 24, 2008 | Energizer 15 Minute Battery Charger Combo...
Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
Nov 20, 2008 | Makita DC24SA 24 Volt Makstar Battery...
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
The battery charger problems
Try those hereunder mentioned.
1. Clean the battery charger pin & battery charging point too. If the red light still blinking then replace your battery. Your battery life is finished then.
For confirmation try to charge your battery from others people charger or ask some same battery and fixit in in your charging place. You can short out then which one have problem.
Thanks & waiting for your feedback.
May 29, 2008 | Olympus Camedia D-590 / C-470 Digital...
Video camera jazz dv179 how many hours need to charge
I HAVE THE SOLUTION!!!!! the camera comes with a charger that plugs into the wall and into the usb port on the camera
Oct 27, 2007 | Jazz DV-179 Digital Camera
Charging/power problems on EX-Z55
The problem might be your charger. I would call repairs and tell them you have a defective charger and they can check it for you. You can reach them at 800-706-2534 and then keep choosing option 1 and that will take you into Casio's repair department.
Dec 08, 2006 | Casio Exilim EX-Z55 Digital Camera
Cameras Logo
129 people viewed this question
Top Batteries.com Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Batteries.com Camera Expert? Answer questions, earn points and help others
