Question about Vehicle Parts & Accessories
I need a installation manual for a code alarm surestart LX
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
Disable factory alarm
You are not able to disarm the factory alarm on this vehicle. You will need to have it diagnosed. But the issues sounds to me like the key fob is bad and needs to be replaced
May 19, 2014 | 2007 Kia Spectra LX Sedan
I forgot the unlock code on my Sanyo Katana lX... Pls. help
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Apr 21, 2011 | Sanyo Katana LX Cell Phone
My ford mondeo lx petrol 98' alarm goes off, sometimes more than once i have to keep going to the parking lot to open and close the door only for the alarm to stop but after some time it goes off again.
Your problem is most likely the central locking / alram switch fitted aroun the door lock inside the door void. Try using the passenger door to lock / unlock. If this stops the alarm triggering then you need to replace the switch behind the lock in the drivers door.
Feb 16, 2011 | Code-Alarm Code Alarm Transponder
Alarm button broken. Cannot disarm alarm. What do I do? Chrysler Town & Country LX 2003 model.
You can arm or disarm alarm manually with the key at the drivers side door, turn the key to open the locks and the alarm must be disarmed.
Nov 01, 2010 | 2003 Chrysler Town & Country
I need a Denso SCV (suction control valve) for my Mazda 6 diesel pump. Part number RFY313SMOA.
you can buy it in SURESTART DIESEL INJECTION SERVICES address Shaw Lne Industral Estate, Doncaster (01302) 340467
Mar 09, 2010 | 2004 Mazda 6
2001 kia optima lx keyless entry system reprogram
The 01 Optima had the keyless entry buttons right on the key itself. I'm not sure if the LX had the option... it was standard on the SE version. In any case, programming is done at the dealership, and is expensive. They use their special "code reader / writer" that plugs into the OBD II port under the dash. You provide all keys and they are recoded to the module that is located under the stereo. A cheaper option might be an aftermarket alarm installed at a local car audio shop. They are less expensive than you might think, even installed. Good luck.
P.S. the 01 Optima remote key had a problem with very short range. You needed to be within a few feet of the doors for it to work.
Dec 05, 2009 | 2001 Kia Optima
Where is the Alarm Valet Switch on a 1997 Honda Accord LX. The alarm was installed prior to purchase of the new car in 1997, but came with a separate manual. The Manual has no info about who designed, or...
it SHOULD be installed on the left kick panel where your left foot would hit if you were driving it. if not pull that panel off and look there the installer might have had a lazy day or left his drill at home but its there somewhere
Sep 30, 2009 | 1997 Honda Accord
Where is the valet switch for honda accord 2002 lx?
Does the vehicle have an aftermarket alarm system? Is the valet switch for this what you are looking for? If so, it depends entirely on who installed it as where they have put it, although it's usually under the dash on the driver’s side. Some alarms have different sequences that you have to go through to put the alarm into valet mode; it's not usually just a switch that you flick. Best to pop into an alarm or stereo installer and see if they can spot it for you, or if the car is immobilized, find out what sort of alarm it is and call an installer for the info on the valet procedure.
Thank You for contacting Fixya.com
Aug 03, 2009 | 2008 Honda Accord
MPV LX alarm issue
Get your money back from the one that installed this alarm.
Jan 05, 2009 | 2000 Mazda MPV
Vehicle Parts & Accessories Logo
615 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
