When machine is filling up either to wash or rinse it overflows
  • 126 Answers
  1. Does the machine continue to fill with unit unplugged? If yes replace water valve. No ,next step.
  2. Locate the pressure or water level switch in the control panel .Lokk for the hose connected to it and make sure it is not kinked or blocked,disconnect and blow thru it to confirm.
  3. If hose is fine replace pressure switch
  4. Hope this helps .Please rate my response :)
Posted on Dec 13, 2009
    President:
  • 1,218 Answers
Good day,
You did not give the make, model number, or style.
If it is a top loader, then the first question is......
How do you stop the filling process. If you have turn the hand valves off to stop the water, then it is a defective water fill valve, located on the back of the machine.
If you can turn it off, by turning the timer off, then it can be one of three items.
1. The pressure switch which is located in the consule in the same area as the timer.
2. The plastic hose that connects from the pressure switch has either come off, or is broken.
3. The plastic hose goes to the bottom of the tube.
Under normal conditions as the tub fills, water starts rising in that hose and applies enough pressure to the pressure switch, to shut off the water, and start the wash or rinse.
To test, access the pressure switch, and pull the plastic hose off at the switch. If not broken, and with a small amount of water in the tube, blow into the hose.
If it is dirt, you should be able to blow it out, and hear a gurgling sound . If it blows freely it is broken or disconnected.
If no luck, and everything checks O.K. then the pressure switch needs to be replaced.
Caution: some recommend blowing in the pressure switch, to see if it clicks. Be aware that switch works on very low pressure, (water inches) and can be easily damaged if too much pressure is applied.
Posted on Dec 12, 2009
  • John Hall Dec 12, 2009
    P.S. If you do the testing as described. Always spin all water out before attempting a fill test.
    The pressure switch will not recognize the water already in the tub, and cause an overfill problem of it's own.
  • John Hall Dec 13, 2009
    Sorry, you are still not finding a soulution.
    I gave what information without knowing the machine model number and style.
    If you want any additional input from me, then I would need that data.
    My suggestions were generic, because of that.
    Jack..
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. This usually happens with just the cold or hot and not both although it can happen.
If it keeps filling and doesn't start the cycle it's the pressure switch.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Washer overflows water when filling
The water level switch is either bad or the tube connected to it is plugged. Tube goes from bottom of tube to switch. Take this off of switch and blow it out. Should solve problem, if not replace water level switch.
Jun 15, 2009 | GE Washing Machines
Washing machine is overflowing in the rinse cycle
the front panel comes off,i think there is 2 screws on the front bottom,if not there should be spring clips in the top front seam on on each side,check the clear hose going to the tub,make sure nothing is in it and it is on tight,check the other side of the hose is behind the head panel,do the same there,if they both go good then you have a bad water level switch,let me know
Apr 23, 2009 | Washing Machines
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Washer overflows on any water level selection
check the pressure tube from the tub to the water level switch for a hole or crack in the tube, if none found replace the water level switch
May 27, 2008 | Crosley Washing Machines
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
Washing machine filling
turn the power off if the water stops it most likley a pressure switch problem or the pressure tube on the side of the outer tank may have pulled off.if you turn the power off and the water doesnt stop then the valve is faulty (cold)if it was on the rinse.hope this helps.
Mar 17, 2008 | Admiral AW22 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing machine overflows
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | GE WJSR1070A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
