Question about Microsoft Xbox 360 Console
Why does my xbox 360 not have those green circles flashing around the power symbol
  • 129 Answers
It has no power in the xbox.
Posted on Dec 14, 2009
SOURCE:
How do i sync the wirless controller to the xbox
There's a button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around the xbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I've linked a video for both the Xbox 360 and Xbox 360 Slim.
Jun 27, 2011 | Microsoft Xbox 360 Controller
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
My xbox 360 controller dosent work!I have a black controller and a white one,the white one dosent trun on it just flashes like a freaking comilean!
There's a little button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around thexbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I think there's a little symbol of air waves next to the button.
Try this it should fix your problem
Feb 28, 2011 | Microsoft Wireless Controller for Xbox 360...
When I try to turn on my xbox 360 my controllers do not connect to it. I get the green power light on the front of the xbox 360 and four flashing green lights on my controller. I have tried my...
Press the circle button in front of your xbox 360 and at the same time press the small circle button on your controller ( located near the port where you connect the play and charge kit cable) so they can sync with each other
Sep 16, 2010 | Microsoft Xbox 360 Console
My controller will not link with my xbox. it just flashes 4 green lights around the circle. what can i do?
Did you sync it? here's how to sync it:
Step 1: Power on your Xbox 360 console2_bing.gif. In this guide I'm assuming everyone already has their console2_bing.gif hooked up, if not, contact me.
Step 2: Power on Xbox2_bing.gif 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Step 3: Locate the small circular sync button on your controller. It is near where your controller can be plugged in (between the LB and RB).
Step 4: Locate the small circular sync button on your Xbox 360 console. It is next to Memory Unit slot 2.
Step 5: Press and hold the controller sync button until the green power lights start spinning.
Step 6: While your controller lights are still spinning press and hold the console sync button. The console's lights should spin also, then flash, and finally show the player slot light on both the console and the controller.
Viola! You've synced your wireless controller! You can sync up to four controllers.
Also, you can use this guide to sync to different Xbox 360 consoles. So you can bring only your controller to your friend's house.
Note: If you sync your controller to another console, you will have to re-sync it to your own afterwords.
Jan 23, 2010 | Microsoft Xbox 360 Controller
Wired rock band 1 360 guitar wont connect.
scrap 360 and get a ps3, u wont go wrong and try holding in the xbox circle button thing :)
Jul 16, 2009 | MTV Games Rock Band Bundle for Xbox 360
Can't sync my wireless controller to my xbox 360
Hi
Dono if you did this the right way but when the remote goes in to sync mode in other words the green light goes flashing around in a circle,you need to press the buttton on the console aswell till it does exactly the same only then will they sync and it will pick up
the remote.
Hope this helpes
PS if you would be so kind as to rate my service i would be gratefull
thx
Slitwrists
May 18, 2009 | Microsoft Xbox 360 Controller
Wireless XBox controller won't sync with the PC adapter
I finally found a solution that works for me (most of the time). I bought a USB hub (un-powered at the moment) and the problem seems to have disappeared. The Hub however isn't the solution. Running the controller or the hub from the rear motherboard ports is.
I was initially using the 360 wireless receiver from the front ports on the PC which are driven by a different circuit on the motherboard than those from the rear of the PC.
When the receiver is run from the rear ports or in my case a hub powered from the rear ports it works most of the time.
Ocassionally the receiver doesn't link with the 360 controller however unlike last time when pressing all kind of combinations of re-sync buttons did nothing, all I do now is press the very tiny white button on the front of the controller and it links up like it should within 1.5 seconds.
I hope this helps guys as the controller is great when working.
Cheers
Karl
Dec 25, 2008 | Microsoft Xbox 360 Controller
Xbox 360
Get it sent to Microsoft and get it repaired. Simple!
Sep 12, 2008 | Video Game Consoles & Games
X box 360 controller
Awesome...You are THE MAN!!! WORKS GREAT
Jul 21, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
