Question about Drills
2 speeds- high torque works -high speed does not cordless drill (firestorm)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Check switch
Posted on Dec 15, 2009
My cordless drill is running at half RPM. Is it the brushes or the motor?
cordless drills have a switch that allows for more torque at lower rpms si in effect it is a 2 speed drill coupled with a variable speed switch that alters the rpms
If the drill is running I would be looking at a speed control problem at this point I would be looking at the torque control switch
Jul 01, 2015 | Milwaukee Hand Trucks Milwaukee Electric...
What do the numbers mean near the front? Does it go around with less speed on 3 than 32?
this is most likely torque settings to keep operator from running screws to deep or snapping them
Jan 11, 2012 | Black & Decker Black and Decker FIRESTORM...
Problems with torque clutch in new DeWalt tranmission
hi
like most clutches on hummer unit after the assembly has been done you will a way to tighten the spring clutch look for adjustment to make the spring looser and tighten
Mar 10, 2017 | Dewalt DC925 Cordless Drill
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
Cordless drill question
1/2"
A 24 position clutch controls torque output. 2 speed range gear box for high torque applications. Auxiliary handle with metal depth stop rod. Has an overmold grip handle for added comfort. A Mag Tray holds screws, small bits and hardware, etc. on foot of drill for easy access. 1/2 Ft.' heavy duty keyless chuck for quick and easy bit changes. Removable 2 position level for convenience and accuracy
Apr 19, 2010 | Ryobi 18v Variable Speed Impact Driver...
How do I determine when to yse high speed /low
High spped for drilling
Low speed for driving scrrews.
Sep 05, 2009 | Drills
Makita 14.4V Cordless Impact Driver only works at high speed
Most cordless drill / drivers like this have electronic switchs which unfortunately would have to be fixed by a repair agent. Depending on it's age - make sure that you tell the agent that it never really worked properly, warrentys only cover parts that were faulty from manufacture and not wear and tear, so it may get fixed for free depending on the repair centre
May 18, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
New cordless drill won't run with charged batteries
Does the drill do anything? Check in the cavity where the battery goes and make sure there is nothing there to prevent the battery contacts from connecting with switch. I take it the charger indicates the batterys are fully charged. If you cant see anything obvious I would take it back and get a replacement.
Dave
Dec 26, 2008 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Mar 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
Top Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Drill Expert? Answer questions, earn points and help others
