Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Selectric III - ribbon won't turn
I have an IBM selectric III - the ribbon cartridge is new and can be manually turned, however, it won't turn when typing, thus using all the ink off one spot and then nothing.
What can I do to make the ribbon move without manually turning it?
Thanks
  • merrygirl Feb 06, 2008
    my newly installed ribbon also won't turn and although I put the ribbon on the outside of the white "shock" post, it still will not advance ....It must be my installation, because it worked fine until I changed the ribbon. This is my last ribbon. Any suggestions?? Thanks!
  • mmay291 Jan 28, 2009
    I have the same problem, with the ribbon outside the shockwire, and installed according to the manual. When I try to type, the ribbon simply won't move. Any ideas what to do? Thanks!
    MM
  • 482 Answers
Make sure the ribbon cartridge lever is closed and that the ribbon is on the outside of the shock wire (where the ribbon exits the left side of the cartridge)
Posted on Jan 21, 2008
6ya staff
SOURCE:
The typewriter ribbon does not want to turn when typing
If you have moved the red lever from the front to thje right and it dosen't feed be sure the ribbon is to the L. of the slacker finger where the ribbon comes out of the cartridge if that is OK try some WD40 on thearm with the spiked driver on th end they do gum up and not engage the ribbon.
DickyO
Mar 05, 2013 | IBM Correcting Selectric Iii Typewriter...
Not correcting & corrector ribbon not moving to correct
At this point almost all selectrics suffer from a case of the gummies.
it most likely needs a tech that under stands the selectric.
DickyO
Aug 28, 2012 | IBM Correcting Selectric Iii Typewriter...
Selectric III typewriter
Go to lexmark.com and click your way to publications there you will find a manual with pictures and instructions on the ribbon.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
I have an IBM Selectric III. When I initially
Try putting some WD40 on the silver shaft that the carrier slides on and also lube the pulleys in both ends.
DickyO
Mar 10, 2010 | IBM Office Equipment & Supplies
HAVING TROUBLE PROPERLY CHANGING A CORRECTABLE RIBBON IN AN IBM SELECTRA 111 TYPEWRITER
Go to lexmark.com , click yuor way to publications there you will find an operators manual. The pictures and descriptions are better than mine. (Be sure you have the right ribbon Selectric III takes two different ribbons)
DickyO
Sep 23, 2009 | IBM Office Equipment & Supplies
I need to know how to install a ribbon on an IBM Selectric III typewriter.
Go to lexmark.com and click your way to publications there you can get instructions and pictures of installation. Remember there are 2 different ribbons for Selectric III,s.
DickyO
Sep 19, 2009 | IBM Office Equipment & Supplies
IBM SELECTRIC III, won't print
try turning the metal shaft that the carrier is on. turn it towards the back of the machine.
Apr 10, 2009 | IBM Wheelwriter 30 Typewriter
Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Mar 11, 2009 | Office Equipment & Supplies
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
831 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
