Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My Bissell steam cleaner appears to have suction at the connecting point for the receiving tank but it does not collect the disbursed liquid and cleaner either on the floor mode or the handle tool. The floor is soaking wet!
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghjd
Posted on Sep 30, 2010
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
Where is the red lint filter that is described in your troubleshooting for lost suction??
It is on the bottom, close to the spinning brushes. It is the red plastic pushed down into the input of the vacum turbine tunnel that utilizes the vacum from the water collection tank to spin the brushes. Make sure that the stem of the master brush is not broken off, after pulling up and out to remove the brush holding container.
Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell steam cleaner will not spray any water
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will not **** the water off the carpet.
If the carpet cleaner won't "Extract" water from the carpet, try using the upholstery / hand tool. If you have suction there, your selector switch / knob is either in wrong position, or broken. There may also be a tear in the hose on the inside of the cleaner, or the waste tank is not sealing well.
Jun 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell carpet cleaner doesn't **** up water
Turn the selector on the side from tools to floor.
Oh yea, could also be the seal is missing from between the tank and the suction nozzle. Could also be the tank is not seated correctly.
May 23, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Jun 30, 2009 | Bissell 9200 Upright Vacuum
No suction of liquid off floor.
This unit has to have some type of clogg in the hose or unde neath the unit. Check to make sure that you have suction in the hose first.
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Steam cleaner will not **** up water
Apr 08, 2009 | Bissell 9200 Upright Vacuum
Does the cleaner solution go in small tank. Should the little tube be down in solution?
http://www.bissell.com/Product_Search.aspx?Criteria=1699
Above is a link to bissell.com where you can get the full user manual. But to answer your questions, the cleaning solution does go into the small tank with the tube, the tube should be arched and go to the bottom corner of the small tank. Clean hot (not boiling) tap water goes into the inner bladder of the big tank. Fill it till you can see the water near the top.
Oct 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
248 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
