Question about Home
Trying to get instruction on grohe 34-124 grotherm thermostat adjustment. Thanks
  • arby1327 Dec 12, 2009
    My issue is to try and get the temp as cool as possible (70 degees. I have not figured out how to get the trim off as i cannot remove the handle. Thx
    I am trying to adjust the temperature down (cooler on a grohe 34 124 thermostat valve (grotherm). I have not been able to remove grip ring handle in order tp access the valve. Thx
  • 8,197 Answers
To get manual for the thermostat you need to contact Grohe at link below.
http://www.groheamerica.com/p/25_16615.html
Posted on Dec 12, 2009
  • 3,230 Answers
Please follow the below steps -
1. Press in the safety lock located at the top of the hot water safety valve. The safety lock, if installed properly, is behind the actual hot water handle and flush against the wall. The safety lock must be depressed to move the safety valve.
2. Turn the circular dial of the safety valve clockwise to increase the temperature of the water. The safety valve, when attached, can only turn half way to the right (clockwise), effectively limiting the temperature to 90 percent of what your pipes are capable of without the safety valve.
3. Turn the circular dial to the left (counterclockwise) to activate the safety valve and reduce the maximum temperature the faucet is capable of. This in effect limits the amount of hot water that is mixed with cold water. You will always get a certain amount of cold water even if the cold water handle is in the "off" position.
Good Luck!!
Thanks
Grotherm 3000 does not turn off
The built-in thermostat only shuts off the upper outlet. An
additional stop valve must be fitted if the lower outlet is used.
Mar 14, 2014 | Computers & Internet
I have a grohe 19 614 thermostatic valve / mixer. I want to adjust it so that the wateris hotter than what is coming out right now. I have the diagram showing how to take the trim off, and shows where to...
http://docs.homeclick.com/PE-Links/Grohe/Grohe-19614-manual.pdf
1. Turn thermostat handle (L) to the 100 °F (38 °C) safety
check, see fig. [6].
2. Unscrew handle (N) or lever (O).
3. Unscrew cap (M).
4. Pull off thermostat handle (L).
5. Remove screws (H) and escutcheon (G), see fig. [4].
6. Close both isolation valves (I).
7. Pull sleeve (F) from the mixer shank by pressing
down the tongue (D2), see fig. [7].
8. Extract clamp (D1).
9. Pull stop ring (D) until resistance is encountered
(approximately 3/8" [10mm]), see fig. [8].
10. Unscrew stop ring (D) complete with regulator
nut (K).
11. Unscrew thermoelement (47 050, 47 582) with 24mm
open-ended wrench, see page 2.
It is not too clear to me, but I'm not looking at it. lol
Gary
Dec 14, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
HOW TO ADJUST A MODEL 34122 gROHE VALVE
there should be a flat head screw on the mixing valve turn the water on and turn it to the desired temp,, it is letting to much cold water in , if this does not work replace the mising valve
Apr 11, 2009 | Grohe Grohtherm Thermostatic Rough-In...
Home Logo
90 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
