I have an ig7 and it started not booting and was beeping at me. someone said bad ram. i replaced the ram and now long slow beeps
  • 21 Answers
Http://www.computerhope.com/beep.htm
Not Knowing what sequence you are getting your beeps
Go into the site above & will give you the problem
Posted on Dec 12, 2009
SOURCE:
Slow start up and beeps a couple of times
The beep pattern tells you what is wrong. Search Google for the exact pattern...ie 2 short beeps, 2 long beeps, etc. Could be bad RAM chip or bad motherboard or video card, etc. The beep pattern will tell you what needs to be fixed.
Mar 25, 2014 | HP Compaq Presario R4000 Notebook
CONTINUOUS BEEP SOUND DURING BOOT
The beep sound is sometimes an indication of the successful boot. But, if the beep is continuous, it usually means a memory problem. I*t could be a failing ram stick or a failing memory cache on the cpu. Try substituting the ram sticks one at a time to eliminate each one.
Aug 02, 2012 | Intel Computers & Internet
WHEN BOOTING THE TOSHIBA SATELLITE A215-S5837 I hear two beeps and get a dark screen. I can press f1 and go into safe mode but don't know what to do next. The error message is "resource conflict...
These beeps are error code and two short beeps during start up normally refers to RAM or memory not being detected. You can try to reseat the RAM modules or ask someone who knows how to do it. If it will still be the same, it means that the RAM is defective and consider replacing it.
Cheers!
Apr 07, 2011 | Toshiba Satellite A215-S5837 Laptop
My apple macbook won't start and continuously keeps on giving a beep sound.
the beep pre-boot is signaling a kernel panic. It could be bad ram or something else, it's hard to tell without hearing the beep (they signify different things)
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
taken from http://www.welovemacs.com/whdoallthbme.html
So depending on the beep, it means different things. However in any case I'd suggest taking it to an Apple Authorized Repair Facility. Unless you feel comfortable with assessing the proper solution on your own
Good Luck.
Feb 17, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Compaq presario m2000 notebook continuously beeps while starting up. The computer is very slow once fully logged in. Do you have any suggestions to fix these problems?
The beeping usually points to a RAM stick failure. If your laptop has two sticks of RAM then one of them has failed, which further explains the slow performance of the laptop once it's fully loaded.
To troubleshoot this issue, you'll need to remove one RAM stick at a time, and see if the laptop boots at all. When you have only one stick of RAM and the laptop does not load after the beep signal, then that installed RAM stick is bad. You may want to try and clean up the contacts with a cotton cloth and some alcohol just to make sure it's not an oxidized contact issue.
If this was informative and helpful please vote with a Thumb Up. Thank you.
Feb 01, 2011 | Compaq Presario M2000 Notebook
On power up it beeps 3 to 4 times and won't boot up
If there is no display coming on your screen check your computer RAM here is the beep codes for your dell computer i hope this will work for you
Regards
manish
Mar 24, 2010 | Dell Inspiron 530 Desktop Computer...
My pc doesn't boot anymore.
This code usually refers to a Video card or RAM issue. Try reseating both the video card and then RAM to see if it fixes the problem. If not then try removing the video card and rebooting. If the system starts without the beeps then you'll know the video card is bad and you can replace it. If it still beeps then try removing the RAM one stick at a time, rebooting after each removal. When it boots you'll have the bad RAM stick isolated and can replace. Hope this helps.
Oct 11, 2009 | ASUS P4P800-VM Motherboard
I have thinkcenter machine when i boot the machine continous beep is originating first small beep and then continous beep and behave like this and system does not boot please suggest
Yes those beeps are a beep code. The way it is currently beeping means you have a bad RAM stick. Open case and make sure the RAM is seated correctly, sometimes it can come loose. You can also take one stick out if you have two and reboot. If it does it again then take that RAM out and replace it with the one you took out. If it still beeps then you need to buy new RAM. That will correct the problem.
Please rate this solution with 4 diamonds.
Mar 06, 2009 | IBM ThinkCentre A51 PC Desktop
Beeping before booting
probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Nov 19, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a HP Pavillion DV 2000 laptop with me. When i boot my system it gives 1 long beep followed by two short beeps and the system doesnt boot. I am not sure as what to do. Can someone help me here?
This website:
http://www.pchell.com/hardware/beepcodes.shtml
Lists standard beep codes for computers. The one long, followed by two short beeps indicates a display problem according to the site.
I have heard other people say that the same beep codes specify a RAM problem.
Have you recently installed any new RAM or a new graphics card, or made changes to either.
It seems likely to be the graphics card because of the missing info on the screen. Usually when RAM is bad there is something on the screen.
Jul 17, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
22 people viewed this question
Alun Cox
k24674
