Question about Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse lcd tv parts
I am looking for replacement LCD parts for my westinghouse TV. when the tv is switched on, it flashes the blue screen and then goes black. you can hear the tv volume but no picture, no numbers/menu display. I took the back off  and dug in a bit and found that the outside 2 terminals of the power cable-to-control panel connector are burnt. the female pins are burned, and the male  side are discolored at the base, by solider connection. Im not sure what came first, a faulty terminal or a faulty part but either way, i need parts. i suspect the control panel has been compromised, not sure what else. i would love a source for parts or part list.  thank you for any help. greg
  • 15 more comments
  • e_zgoin1 Feb 06, 2008
    Yesterday my roomate turned on my screen (I use it as a computer monitor) and it came on as usual, made several clicking noises... I asked my roomate where the cat was, as it sounded like she was playing with a cord, and the screen went black. Never to come back on. I did all the basics, checked connections, outlets, cords... Nothing. I opened the back up and smelled for that distinct "burnt electronics" smell... Again nothing. After talking to Rasheed or Mohammed or someone obviously who uses English as a second language, I got nothing but even more frustrated. After calling several t.v. repair companies, I came to the conclusion it was the DC/DC converter. The Make is Delta Electronics, Inc. And the model # is:DPS-210EP-2 C
    Obviously I researched this part # and found no results. Hopefully someone can help me locate this product.
  • gigaber Feb 18, 2008
    I had the same problem. My power supply board is not operating, I checked the voltages. Have to hand it to Westinghouse for doing a great job on descriptive silkscreen info. Too bad the power board is wimpy. Tried calling Vance Baldwin and they don't have an item list for this TV (LTV-32W3 HD), but they have sent it to their research dept. I hate when people complain about overseas tech support. How do you think you were able to get your TV for so incredibly cheap? Magic?
  • rtgmrfxit May 17, 2008
    yup me too same thing exactly...sure is a bummer...paid $1700.00 for mine about 4 yrs ago... ps i did the same thing with unit..but gave up!
  • Scruffeone May 20, 2008
    same exact problem as described. blue flash then black. sound works well.
  • rwraichle Jul 28, 2008
    The screen is blue - no picture, but do get sound.
  • Anonymous Nov 29, 2008
    dvd play will not take disc
  • ce60 Jan 19, 2009
    apparently this is a common problem. i was wondering could it be the power cord? you know it looks just like the power cord for my computer.
  • grodenbarg
    grodenbarg Jan 20, 2009
    I just now have this occurrence the blue/ then/ blank problem with my 27" LCD tv I purchased 4.25 yrs ago. I have not had the time to disassemble my tv yet, since this problem has just started. :|
  • Anonymous Jan 27, 2009
    picture comes on for a split second then goes black.37"tv less than a year old.is it junk,and have i made a mistake buying westinghouse?is it still under warranty?
  • hutter Apr 05, 2009
    Same problem, set is 14 months old....judging by my research on the net, your best bet is to look at the bright side, you still have your health. These tvs are junk and every penny you invest is in vain.
  • Anonymous Apr 08, 2009
    my tv is 1 year old and just like that it went out still have volume no picture. they said it would cost 400.00-450.00 to fix........... any suggestions?????????
  • imfromladug Apr 19, 2009
    Where can i get the base to the desktop stand for the L2610NM LCD monitor?
  • owingsar Apr 20, 2009
    Westinghouse LCD tv 32in. No picture just sound with a red X that flashed then back to black screen.
  • freser Nov 26, 2009
    Does anyone know what the actual name of the part is that you need to replace? I have the same issue...
  • pnutz409 May 11, 2010
    the entire side with the yellow red white RCA cables along with the ANT and Svideo side has problems. The audio works, but I get no picture on any of them. I do get picture from the rgb component cable side and vga input. What parts would I need?
  • jgalvez Dec 07, 2010
    Hello sir
    I need help
    I have 2 issue that hopefully you can supply me what I needed
    1. LTV46w 1HD B
    THIS TV HAS NO PICTURE AND SOUND, DO YOU SELL THE BOARD
    2. WESTINGHOUSE SK26H57OD
    I HAVE ONLY WHITE SCREEN NO SOUND, MAYBE NEEDS THE SAME BOARD
    3. 15LCDCFTD1529B
    I REPLCE THE BOARD ON THIS TV AND IT WORKS BUT THE ONLY
    THING IS THAT THE THE REMOTE DOES NOT FUNCTION PROPERLY
    DO YOU HAVE A REMOTE CONTROL SENSOR OR KEY CONTROLLER
    WHAT DO YOU THINK SHOULD I CHANGE I WILL NOT TAKE YOU AGAINST IT
    Hello sir
    I need help
    1. LTV46w 1HD B
    3. 15LCDCFTD1529B
  • jack sigsby
    jack sigsby Aug 09, 2013
    try shop jimmy.com
HAVE A WESTINGHOUSE LTV32-6HD. HAS SOUND, NO PICTURE. APPROXIMATELY 8 MONTHS OLD
Posted on Jan 26, 2008
    Problem Solver:
  • 10 Answers
Try this site 4H.B0700.071LCDPARTS.NET I bought this board and it fixed my problem easy to install $150.00
Posted on Dec 11, 2009
  • 2,337 Answers
The only way to get the TVs working again is to fix the power supply assembly to the component level. There isn't many or any service parts available and it looks like they made the TV to be disposable.
Posted on Apr 22, 2008
Look for swollen electrolytic capacitors in the power supply. They will be swollen at the top or "domed".
Posted on Feb 17, 2009
  • 298 Answers
    Problem Solver:
Greggieman, i have a ltv-32w1 too with similar prblems. Did you ever fix yours?
Posted on Apr 19, 2008
    New Friend:
I've had the same problem with a customers tv, and found that T3 transformer was bad. Bad to the point it burnt the board and transformer. T1 and T2 are good. Finding a transformer may be the real problem
Posted on Oct 16, 2010
    New Friend:
I HAVE MY OWN PROBLEM WITH MY ONLY 2 YEAR OLD WESTINGHOUSE 32 IN MODEL SK32H540S FLAT SCREEN TV THAT WITH NO WARNING AT ALL STOPPED WORKING, THE AUDIO WORKS BUT NOT THE VIDEO. THE WESTINGHOUSE LOGO STILL COMES ON THE TV BUT THE TV TURNS OFF AND ALL YOU GET IS A BIG BLANK BLACK SCREEN. I TRIED EMAILING WESTINGHOUSE ON THEIR COMPANY WEBSITE BUT IT KEEPS TELLING ME IT WON'T GO THROUGH BECAUSE OF THE WRONG ACCESS CODE.
Posted on Jul 01, 2010
Where can i find a power supply at?
Posted on Aug 12, 2008
YOU CAN TRY AND ORDER THE POWER SUPPLY FROM ANDREWS ELECTRONICS IN CALIFORNIA . THIS IS A COMMON PROBLEM , THEY USE CHEAP CAPACITORS IN THIER POWER SUPPLIES , I KNOW BECUASE I HAVE FIXED SOME OF THEM.
Posted on Aug 05, 2008
3 Suggested Answers
SOURCE:
  • 2337 Answers
SOURCE: westinghouse lcd tv parts
Check this LINK to see if they have any available parts.
Posted on Feb 26, 2008
can I have your LCD SCREEN? Mine is cracked and I sure could use a new one, or used if thats the case =)
Posted on Aug 29, 2008
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Westinghouse tv won`t turn on. blue light is lit
westinghouse flat screen ...blue light on lower part...can not get to stay on tv and no sound...what button so i push to go back to tv
Feb 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse SK-26H520S LCD TV has blue screen on the side
Vertical color scan has an open or short..............it could also be a ground problem with in the V-color scan circuits...
If you tap the tv and the color bar is gone then its a ground problem with in those circuits above. Needs a solder re-flow and check the condition of ribbon cables.
CWR
Oct 29, 2009 | Westinghouse Televison & Video
Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Oct 01, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Aug 20, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Feb 26, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Nov 11, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
No video
Possible bad main board or panel.
May 27, 2007 | Westinghouse W32701 27 in. LCD HDTV
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
21,368 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
