Question about Canon PIXMA MP600 all-In-One InkJet Printer
I was replacing my surge suppressor and when I plugged my MP600 back in, all the menus are in Japanese. How do I get them back to English?
    President:
  • 2,030 Answers
Goto the setup menu and select language.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Dec 12, 2009
Tread mill wont turn on. it was on then while in use the screen flashed on and off then treadmill shut down and has not turned back on. tried reset button then unpluging for a while but still does not turn...
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Sep 13, 2011 | Nordic Track NordicTrack Elite zi...
Japanese version
I am sorry but the Japanese Wii has no option for English language menus. All Wii menus will be in Japanese.
Dec 23, 2007 | Nintendo Wii Console
What type of AC adapter does the T790 ellictical machine needs also the voltage and polarity
Dear Sir:
Please read carefully:
Your treadmill, like any other type of sophisticated
electronic equipment, can be seriously damaged by
sudden voltage changes in your homeõs power.
Voltage surges, spikes, and noise interference can
result from weather conditions or from other appliances
being turned on or off. To decrease the possibility of
your treadmill being damaged, always use a surge
suppressor with your treadmill (see drawing 1 at
the right).
To purchase a surge suppressor, see your local
PROFORM dealer or call toll-free 1-800-366-7278
and order part number 14657. Use only a single-outlet
surge suppressor that is UL 1449 listed as a transient
suppressor must have a UL suppressed voltage rating
of 400 volts or less and a minimum surge dissipation of
This product must be grounded. If it should malfunction
or break down, grounding provides a path of least
resistance for electric current to reduce the risk of electric
shock. This product is equipped with a cord having
an equipment-grounding conductor and a grounding
plug. Plug the power cord into a surge suppressor,
and plug the surge suppressor into an appropriate
outlet that is properly installed and grounded in
accordance with all local codes and ordinances.
If you need Extra help please reach me inmediately.
sincerely. blessing.
E.CUADRA
MANAGUA, NICARAGUA .C.A
Sep 13, 2011 | Reebok Exercise & Fitness
My wii is in japanese want to change to english just bought it off a friend
Hey Matt. The Japanese version cannot be changed to English language menus. Sorry. However here is a link that might help.
http://www.sheylara.com/wii/wii_system_settings_translation_v1.0.pdf
It gives the english translations of the menus.
Oct 16, 2010 | Computers & Internet
The power went off in my house for 15 minutes. When it came back on everything worked except the Gateway PC with Windows XP and the monitor which was connected to a surge suppressor. The PC won;t come on...
If the monitor is out as well then the surge suppressor did its job and took the hit, basically rendering it useless now, try plugging in the system and monitor directly to the wall, it they work then you need to replace the surge suppressor.
Sep 19, 2009 | Gateway GT5220 PC Desktop
Printer Canon MP600 turned Japanese!
There are language settings. Go to the main menu and rotate through to the pliers/screwdriver icon. (settings) Click the right button to select the icon with two sliding tabs. (device settings) Scroll down 4 selections to language selection. Select English.
Dec 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My Canon MP600 has suddenly decided to speak Japanese!! How do I get back to english????
consult the user mannual, in the language section u will find the way to change the language
Printer reset itself in Japanese
My Canon Mp600 has reset itself in Japanese about 4 times over the last 18months, so I now keep a set of instructions taped to the side of the printer. Switch on the printer and get it to the home setting by pressing the HOME button and press buttons as follows:
1. Press the RIGHT arrow on the central wheel until you get the SETTINGS option (spanner & screwdriver icon). Press OK.
2. Press the RIGHT arrow on the central wheel once to select the slider icon on the right hand side. Press OK.
3. Press the DOWN arrow on the central wheel FOUR times. Press OK.
4. Select ENGLISH from the list of languages. Press OK.
5. Attached these instructions to your printer so you have them to hand next time it goes Japanese!!
Sep 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer info is in Japanese - HELP
you'll need to download the newest drivers, in english
follow this link to the Canon icon, and enter your model number and operating system.
and make sure it's in English
Mar 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
79 people viewed this question
Clive
Clive
old marine
old marine
