Question about Coleman Heating & Cooling
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the codes?
  • 1,420 Answers
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Posted on Dec 12, 2009
Testimonial: "thanks very much, the info was exactly what i needed.i dont know why it was not on the panels but thank you "
SOURCE:
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
Shuts down after 5 minutes blinks green
Once the set shuts down, wait for the unit to stop blinking. Once it stops hold in the input and menu buttons for 5 seconds. The TV will then give you an error code. A 6-1 or a 1-8 error code would indicate a bad Color wheel. Which I think is the problem you have.
Jun 19, 2012 | Mitsubishi WD-65735 Television
I have a friedrich ductless split m# mw24cy3f .. call for cool only fan runs inside, call for heat nothing runs, outdoor temp at the moment is 38 degrees, error code light blinks on indoor unit......
not able to find the error codes for the unit number you gave but, here is a number you can call to get them. sorry not more help.
1-866-793-0323 spacer.gif Mon - Fri 9:00am to 6:00pm EST
Dec 20, 2010 | Friedrich Heating & Cooling
On a 80% Rheem upflow furnace... The AC works fine but when switched to heat nothing happens. "OK" LED is on solid, second LED is blinking 3 times, "FLAME" LED is not on at all. What can be the problem?
Hello ANGUS,I think 3 blinks is open pressure switch,try taking the door off the furnace.The upper left hand side is a round black box with a hose attached to it .Gently tap the switch(box) and turn off power for 2 seconds andback on,then call for heat.the blower door has a sticker inside that tells you just what the blinks mean.
Aug 10, 2010 | Heating & Cooling
Error code 5 blinks, then 6. unit turns on then off with no call for heat, i just dont have access to the manual,.
Look on one of the removable panels for a glued on wiring diagram. On the diagram will be an error code diagnostic chart. It will help you with a starting point where to look.
Dec 12, 2009 | Applica Heating & Cooling
6 red blinking codes
Below is picture of error code table of Sony TV KP-57WS500You can check what is error 5 and 6
Oct 31, 2008 | Sony KP-57WS500 57" Rear Projection...
Not turn on i do not have 24v. Was watching TV for three hours when I was finished the set would not turn off from either remote or front panel. Unplugged unit and left overnight. When I plugged the unit...
Good Day,
The most common problem with this Model is the Caps on the Main Board, but to make sure pull the codes. Follow this procedure:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Heating & Cooling Logo
739 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
