I have 2 Toshiba dvd recorders in the same space, and the remotes affect both devices, which is a problem. Can they be distinguoshed?
    Sergeant:
  • 210 Answers
Cover sencer on the one that not in use
Posted on Dec 12, 2009
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
I cannot make my toshiba dvd recorder work with
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Mar 22, 2010 | RCA 3-Device Universal Remote with...
What is the setup code for the DVD Video Recorder D-R410KU to control the player with the cable box remote?
I have found the code for the Toshiba D-R410 DVD recorder ! The code that works with my Radio Shack family 5 in 1 remote is:
1008
I hope this helps !
Feb 06, 2010 | Toshiba DR410 DVD Recorder
What's the remote code to activate with a
1008
I hope this helps !
Jan 03, 2010 | Toshiba DR410 DVD Recorder
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
What is the Code for a TOSHIBA DVD Video Recorder Mdl. #D-R550?
Here you go. Follow the link.
http://www.comcast.com/remotes/dvdcodes.html
I hope this solution is helpful. Please remember to rate this solution.
Feb 13, 2009 | Toshiba DR550 DVD Recorder
HIGH-SPEED DUBBING TOSHIBA RD-XS34
Press the 'Display' button on the remote control.
Dec 05, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
Top Televison & Video Experts
