Question about Brother MFC-7820N Laser Printer
Everything I print comes out light. I tried setting the contrast to maximum darkness but it does not help that much. The toner cartridge is not that old
  • 14 Answers
I can fix the problem for $50 plus shipping.
Posted on Jan 23, 2010
  • repairguyz20 Jan 23, 2010
    Email me at: repairguyz2004@gmail.com for detail.
SOURCE:
Scx4623f problem with printing right side dark and left side deem
Try to remove toner cartridge and shake, plug in and make a self test print. if not work, you need to change new toner cartridge to make sure that the problem is not with printer itself.
Feb 11, 2014 | Samsung SCX4623F AllInOne Laser Printer
Smear when printing
Hi Juan.
I take it that you have a laser printer; i.e. toner cartridge.
You have probably checked your user manual.
It could be that the toner cartridge is nearly empty.
Purchase a new cartridge, and carefully replace the existing cartridge.
Many cartridges have an inbuilt fuser.
You can try cleaning all the rollers, the toner cartridge, and the fuser, but as the printing is light, you may be nearly out of toner.
Jan 30, 2014 | Office Equipment & Supplies
Pages are printing dark (like there's too much toner coming out)
Are you using a compatible toner, or original..
If compatible, go into the settings and lighten the print.
If original, could be faulty... but I would say it's the toner.
Try another if you have one.
Feb 06, 2018 | Brother HL-2170W Laser Printer
Won't print dark enough
Forget buying a new toner cartridge and don't bother re-installing anything - This is a power supply problem - The electrolytic capacitors fade away after a few years of power on and the high voltage to the printing engine drops too low.I tried a new toner cartridge - no help - re-installed drivers - no help.If you can handle a soldering iron or know a friend who can, replace the following capacitors on the power supply board on the LHS (power cord side). Make sure you use low impedance 105 degree power supply types. Warning - high voltage !!! power cord out and wait 30 minutes before touching anything.
C374 341 503 529 (47uF/35V), C526 (1uf/50V), C506 (0.47uF/35V), C515 (100uf/50V). All the others tested fine in mine. Also make sure you install them the correct way around!
Now I have "black as black can be" prints just like new and I can set print density back to 2 not 5.
enjoy ;-)
Apr 24, 2012 | HP LaserJet 3030 All-In-One Printer
Printed pages are light on both sides of page.
This is usually a sign that the toner cartridge is running low on toner. Replace the toner cartridge and see if the problem persists. If not, then problem solved.
If the problem persists, try adjusting the darkness settings in the printer settings when you are about to print. Sometimes even one notch darker can make a large difference.
Feb 28, 2011 | HP LaserJet 2430dtn Printer
My HP 5200 printer prints very light as if its cartridge is low while its toner is full, this problem was present from the very first day i purchased it, changed toner cartridge but no effect, (meaning no...
Try changing you Print Quality Settings.
1. Go to your Printers and Faxes(XP), Printers(Vista), Devices and Printers(Win7) 2. Right Click on Your Printer Icon 3. Click on Printing Preferences 4. On Print Quality, Choose Best. 5. Under Features -- Check the box for Print in Maximum DPI.
I hope this helped a little :)
Feb 04, 2011 | HP LaserJet 5200 Printer
Print very light
change your printer setting to BEST PHOTO setting
May 04, 2009 | Brother MFC-7820N Laser Printer
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Toner prints to dark
hi!!!!!
try to re-install the driver of your printer!!!
or try to figureout the settings of your printer
New scx-4521-FG/ too much fad
The darkest copy setting is obtained when the contrast is set to dark and the toner save is turned off. If the originals being copied are too light, this unit has trouble seeing the image and the copies are extremely light as well. If the originals are good and dark, try using original toner cartridges.
Be blessed.
Oct 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Brother MFC-7820N Laser Printer Logo
131 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
