Question about E-Machines eMachines Desktop PC
Did system recovery and missed the part where we were suopposed to put in the disk. is there a way to get the disk to run, it wont let me do another recovery.
    President:
  • 2,030 Answers
YOU have to start from the beginning, if when you put in the disk nothing happens.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Dec 12, 2009
SOURCE:
Computer wont boot completely up missing or corrupt files
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 01, 2012 | Systemax Venture PC Desktop
I have a dell inspiron 8500. Occasionally it would go through post and come up with disk read error press ctrl alt del to restart then it came up with the ntfs.sys file was missing. I manually reinstalled...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 12, 2011 | Dell Inspiron 8500 Notebook
Boot manager missing problem:
I successfully formatted my Toshiba Satelite laptop using the original recovery disks. However, when I try to restore it using the recovery disks, the systems gives an error message of BOOT MANAGER IS MISSING. The system doesn't recognize the recovery disks and I can not install (reinstall) the Windows Vista on the mechine.
Please help me.
Sep 15, 2010 | Computers & Internet
My laptop does not working and some windows file missing pls give me advise how to recovery my window
You need to have windows disk in oreder to repair or reinstall windows, IF you have it, insert it in drive and restart your computer and follow the instructions on the screen to install windows, if you are using HP or dell laptop then you must have the recovery disks from which you can do recovery, if you misplace it then you may get in touch with HP or DELL and they will provide you the set of recovery disk.
Mar 23, 2010 | Computers & Internet
I need to get my computer back to the settings which were, when i first bought it. it wont let me open files i just wanna do the recovery with system disk and the three recovery disks but it wont let me
thats because to run the recovery disks you have to shut down yor pc then select boot options its displayed on the first screen afta u boot it, then select boot from cd rom drive and it will automatically begin to run the recovery program
Nov 17, 2009 | Acer Aspire 9500 Notebook
Can;t reboot it says lost bootmsg file
recovery disk will not work in this case. wat u need to do is to repair ur operating system. plz try repairing ur operating system with a bootable cd because the missing file is a system file that supports the operating system. hope this solves your problem
Mar 31, 2009 | Computers & Internet
Install window is telling me the computer started unexpectedly or encountered an unexpected error.windows instalation cannot proced. to install windows click ok to restart computer and then restart the...
You need the disk, it needs to replace the damaged files, Is this an XP system. Any disk will work to repair it but you have to have your Origianl to re-install completely.
Once you get one, I can run your through the system repair through Command prompt by booting from disk.
Let me know and good luck.
Dec 03, 2008 | Everex Computers & Internet
Boot Manager is missing
you can often fix it right back up using the original Vista installation disk. Which comes with a pretty extensive System Recovery Tool that's got lots of options. Set your computer to boot from DVD (using the Boot setting in the BIOS), insert the disc and restart. Vista will prompt you for language and keyboard layout options, then ask if you want to reinstall Vista or repair your installation. You want Repair. From there Vista's System Recovery Tool will take over. this is the only way to get back from the dreaded boot manager missing error.
Jun 10, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
44 people viewed this question
Top E-Machines Computers & Internet Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
