Question about Honeywell Programmable Thermostat Heater
Furnace blows cold air
The furnace turns on but the thermostat will not heat past 66 degrees and only blow cold air
  • Chandler Ede
    Chandler Ede May 11, 2010
    Can you give us any make and model number of the heating system?
  • Robotinner May 11, 2010
    this may not be a Stat problem but let me ask if the filter is clean?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Posted on Dec 19, 2009
I have a carrier furnace and it seems to be only blowing out lukewarm or cold air and my house only gets up to 63 degrees
Make sure your filter is clean and that your heat registers are open and the cold air return is not blocked. So if you turn your thermostat up to 70 degrees is the burner shutting off before the house gets up to temp? If the thermostat has batteries are they new? Out side of that you may need a service tech.
Jan 01, 2018 | Carrier Heating & Cooling
Why is my furnace blowing cold air?
I depends on if you have gas or electric heat. If electric, you could have blown a fuse. If gas, your pilot light may be out.
Feb 26, 2015 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
The furnace is blowing warm air even if the thermostat low.
The only thing that tells the unit to come on and off is the thermostat so I would definatly say it is it. When you turn the system back on, does the a/c run normally? If it does, then it's the problem with the heating side of the tstat. Also, does the fan come on when you put it to on and then turn of when you switch it back to auto? If it does, then the system is working fine, its the t-stat. Let me know if you have any more problems.
Mar 23, 2009 | Intertherm P3RA-048K Air Conditioner
Hot air blows unless the temp is turned down to 66 degress
well ? Does It get cold @ 66 Degrees? And If so.. Aint 66 degrees cold?
Mar 15, 2009 | 2004 Honda Odyssey
Heating & Cooling Logo
1,491 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
