Question about Honeywell Heating & Cooling
Rheem Critetion II gas furnace will not light, didn't see any lights on either. Is there some type of reset switch?
  • 1,420 Answers
There should be a small window on the lower panel that you can look thru and see if there is power to the circuit board and if there is any error blinks. Check the fuse panel or circuit breaker box for a bad fuse. Sometimes there will be an emergency switch for the furnace in a stairway or closet and above the furnace there may be a red plate with either a black button or silver knob. Check to see if there is an outlet for a condensate pump on the furnace and that the outlet has power. If you are getting power to the furnace but you thermostat is not working, there is a 3 amp 250 volt glass fuse on the circuit board that may have popped. Try cycling the circuit breaker to reset the furnace.
Posted on Dec 12, 2009
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
Furnace stop working after cleaning the electronic air cleaner F50
Try this educational video: https://www.youtube.com/watch?v=erpnfKbqmoM It could be something as simple as a pressure switch.
I hope I helped you out!
Apr 01, 2017 | Honeywell (F50F1032) Air Purifier
How do you lite the pilot lite on a Rheem Gas Furnace Model #rgma-125a
If I recall correctly, model number Rheem furnace you listed has electronic ignition to light the pilot, when the home's thermostat calls for heat. Is this what you're having a problem with?
Mar 11, 2011 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Have a rheem criterion II. Model
The way it lights is that the gas is spread from one burner to the next by either a flame tray or small holes drilled in the burner tubes. If the flame does not get all the way across the burner tubes within a few seconds, the unit goes out on failure. Clean and inspect each burner tube, not just the orifice. Clean any tray that connects the burners. You can use a small wire brush or tooth brush but be careful near the glow igniter as it is very fragile.
Dec 12, 2009 | Heating & Cooling
My rheem cri II furnace will not work unless I turn the gas valve knob from on to off and back. The green led light is blinking then solid when I reset knob. Any ideas?
The green light is flashing an error code. When you turn the knob off and back on you are resetting the safety. Look for the number of blinks in a row. Then find the legend for codes on gas valve or on furnace. When is the last time you changed the air filter? A dirty filter can cause this problem.
Nov 07, 2009 | Heating & Cooling
RHEEM CRITERION II FLAME LIGHT DOES NOT COME ON
1/ overheat stat 2/ fan 3/ diaphrapm valve 4/micro switch when checking fan be sure to check the very small rubberor nylon hose for pinhole best of luck
Oct 29, 2009 | Rheem Paloma PH-20R IFSN / RTG-53PVN...
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The...
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Dec 13, 2008 | Water Heaters
Heating & Cooling Logo
432 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
