Question about KitchenAid KESS908SPS Electric Kitchen Range
New Never used electric range,oven door is no clossing properly,lights are always on
    Novelist:
  • 194 Answers
Unless the door is standing ajar you need to look for the manual light switch. This is normally near the other controls... allows you to light the oven interior without opening the door for food inspection via the window. If the door is standing slightly open then bring it fully down and then attempt to slip it back further into the hing slots. Oven doors normally are removable from the fully horizontal position where their springs become inactive and the stresses on the hinges are zero. This allows the hing plates to slide in or out of the slots on the oven chassis.
Posted on Dec 12, 2009
Can oven door be removed? Will light in oven turn on when door is closed?
Nearly always yes, very easily. Well they were put on weren't they :>)
For drop down doors, open half way and lift the door off upwards.
Now I re-read the questions, you talk about a 'light going off when the door is closed'. Now I think you are talking 'microwave ovens? The answer is firmly NO where a microwave is concerned.
Range Oven lights are always operated by a switch so you have to option of when to switch on and off. Useful for seeing how food is cooking without opening the door and useful for see inside the oven when you are cleaning it with the door open.
Dec 01, 2015 | Kitchen Ranges
Kitchenaid electric range model kesc300, why does oven go on by itself and i cant shut it off unless i closs circuit breaker
Ghosts....
Okay, at this point some trouble shooting is needed. Unless you have a multi-meter and know how to use it you need a professional. Surges in thesource may cause this as well as poor grounds in the builings electrical sysytem.
Oct 09, 2014 | KitchenAid KESC307 Electric Kitchen Range
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
Do you kep door closed when broiling
Hi, yes, your oven door should be closed , at all times whenever you're using it, otherwise your home will become oven, use oven thermostat to maintain temp, door should be closed, especially on broil. knob you turn, to light oven is also a thermostat. good luck.
Aug 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Mar 08, 2009 | Kenmore Kitchen Ranges
After using my electric range self cleaning oven an f90err appeared and the door will not open. I would really like to cook my new years dinner .Can you help please ?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Dec 31, 2008 | Kenmore 96212 / 96214 / 96219 Electric...
Oven door does not close properly
replacing hinges on this oven. Take a look.
Dec 14, 2008 | Hotpoint RB787 Electric Kitchen Range
Open Questions:
KitchenAid KESS908SPS Electric Kitchen Range Logo
203 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
