Question about Singer 7462 Mechanical Sewing Machine
Sewing button for first time. I have followed directions carefully but machine beeps and won't sew when I press on peddle. The machine works just great for all other stitches.
  • 3,230 Answers
Well it seems that there is some wrong operation selected, so check all the directions again, also check that do not put the down thread when you sew a button....., check the needle size, check weather you operate the machine manually or in auto mode.....
Thanks
Posted on Dec 12, 2009
SOURCE:
How do I get my machine to start sewing and stop beeping?
try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Jun 06, 2015 | Singer 7436 - INGENUITY
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
I followed the direction, the pressed the peddle. My stitches are straight instead of zigzag.
For the buttonhole function, there is generally also a lever you must pull down to engage the function. If you DID pull it down, you may not have pulled it down enough, so that it wasn't engaged.
Dec 27, 2013 | Singer Confidence 7469 Mechanical Sewing...
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
Machine beeps three times when buttonhole foot is on and pedal depressed. will not sew buttonhole. i have followed the directions in the manual for attaching presser foot and inserting button
does your manual mention anything about a buttonhole lever that must be pulled down each time you make a buttonhole & then pushed back up afterwards
Aug 06, 2011 | Singer Confidence 7467 Mechanical Sewing...
I was sewing everything was fine. When I changed to zig zag it also worked but, when I switched to straight sewing and pressed the foot peddle the machine began to make a beeping sound and it won't go...
If the needle was on the down position when you switched stiches, this could have caused the problem. Raise the needle completely, power the machine off for 30 seconds, then power back on... Did that fix it?
Jun 22, 2011 | Singer 7436 - INGENUITY
Machine beeps and won't sew when buttonhole foot is attached - I have followed directions very carefully
I just figured out how to use the buttonhole feature today. Make sure where you insert the button is towards the back of the machine. Pull down the button hole lever and make sure it's between to two plastic notches. The buttonhole lever will actually be pressed against notch B as described in the instructions. Insert your material and let the bottonhole foot down. You will to play with the stitch width and length to get the right size opening. I hope this helps!
Dec 12, 2009 | Singer 7462 Mechanical Sewing Machine
Singer 7422 beeps and all lights come on when peddle is pressed.
There are several sensors on this machine that just start causing the machine to malfunction for no apparent reason. One is one the bobbin winder, one on the buttonholer, and one under the machine which workd with the feed. It is far from an exact thing. If you can get to them, sometimes loosening them, moving them about then tightening them seems to 'fix' them. Sometimes not. Wish we could be more exact in explaination but sometimes we will move them repeatedly then they start working. It is hit and miss.
Sep 06, 2009 | Singer 7422
Janome 6500 will only stitch one stitch each time I press the peddle
the lock button is stuck on the front n of you mech.
Apr 15, 2009 | Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
