Question about Polaroid i1035 Digital Camera
My camera lets the little green light come on the immediatly shuts off and theres new batteries
    Guru:
  • 1,738 Answers
It is your flash sensor that is bad.
Posted on Dec 12, 2009
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
My fuji finepix s5600 shuts down when i want to take pics,
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Jan 07, 2010 | Cameras
Camera immediatly shuts off and lense goes back in.
Sounds to me that ist is more of a charger issue. Try to borrow another charger and see if that works or not.
Jun 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Samsung S630 camera says "low battery" then shuts off
You might want to try cleaning the battery contacts in the camera. I usually use a q-tip and rubbing alcohol (not too much, just moisten the tip a little). After doing so, blow in to the camera a couple of times to remove any leftover q-tip fibers and/or alcohol. This happens to me all of the time - the contacts can get a little corrosion/patina on them (even new after manufacturing and storage) that is hardly visible. Good luck.
Jan 11, 2018 | Pentax Optio M30 Digital Camera
Camera will not stay on
C653 Camera worked great, went to take a pic and it went dead red light and green light flashes, but no action, changed batteries still same ... any ideas
Thanks Gord
Mar 28, 2008 | Kodak EasyShare C653 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Not powering on
Remove battery for a minute and insert it again.
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Scroll down to Battery Type
Two options under Battery Type:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Oct 22, 2007 | Samsung Digimax S630 Digital Camera
Olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: http://www.olympusamerica.com/cpg_section/OMfirm.asp And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
Jun 22, 2006 | Olympus SP-350 Digital Camera
Polaroid i1035 Digital Camera Logo
43 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
