Question about RCA DRC8300N DVD Recorder/VCR
My combo DVD/VCR DRC8335 will only display HELLO and not respond to the remote or buttons on the face. I have tried the troubleshooting portion of the manual and need help.
I have an rca drc8335 vcr/dvd player that is locked. I have the code to unlock it, but don't know where to post the code. Can you help me?
Posted on Jan 03, 2010
Many of the capacitors on the power supply may be faulty. Try replacing C216, C218, C219, C226 and C228 with new ones with a 35 volt working voltage rating.
Your local Radio Shack usually carries these caps, and most are $1.59 or less each. Work safely & good luck...
Posted on Feb 21, 2010
Need a remote code for an insignia dvd/vcr combo player
Hello
Four digit universal remote codes for Insignia DVd/VCR combo is:
[0405 0245]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jul 07, 2011 | Insignia IS-DVD040924 DVD Player/VCR
I need codes for my jvc dvd/vcr combo using my bigeasy one for all universal remote urc3300 please
Hello
Four digit universal remote codes for JVC DVD/VCR combo are
0418 0900
Direct Code Entry
OK.
Feb 12, 2011 | Televison & Video
Hello can you gayz tell me how to gat cod for universal remot control my tv is HCT TV/DVD COMBOS
Hello
Three digit universal remote code for Symphonic Tv are:
033/ 053/ 189
Four digit universal remote codes for Syphonic TV are:-
0053 0189 0227 0456 0024
Four digit universal remote code for Symponic tv/vcr combo is
0227
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Ok
Jan 15, 2011 | Symphonic SC309C 9 in. TV/VCR Combo
Need the remote code to my Samsung TV. My model is: TVN5054CA
Hello
Three digit universal remote code for Samsung Tv are:
002 012 102 103 112 212 502 512 818 914
Four digit remote code for Samsung TV/VCR/DVD combo is
0942
DVD/VCR cobo are:-
0455 0963
TV/DVD combo is
0942
Direct Code Entry
OK.
Dec 28, 2010 | Samsung CXD1342 13 in. Combo
What is the tv//dvd/vhs remote code for pv-m2799 treple play como unit?
Hello
Four digit universal remote code for tv/vcr/dvd combo is
0437
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. OK.
Dec 09, 2010 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Unit says hello
This problem is normally caused by a dvd player with a dirty lens that it cannot read or detect a dvd in the player. At the same time if this is a dvd/vcr combo a vcr that will not load or is stuck can cause the problem. These can be checked by taking the screws off the unit and taking a look at the position of the dvd laser lens or the vcr position to see if it is in the fully eject position. The part that holds the laser lens to read the dvds can be moved manually back and forth to dislodge it from a stuck position with the power off. Depending on how long it sat around it could just be stuck. You see when you first turn the power on to the unit initially or try to eject a dvd, it will cycle through and try to read a dvd even though there is not one there on power up. If that assembly that moves the lens to read the dvd cannot move, it will cycle off and turn itself off even though you try to reset it with the power button.
A transistor on the power supply can also cause this problem but without taking signal and voltage measurements it would be difficult to pinpoint the exact one. So try moving the laser lens assembly manually and then turn it back on. Let me know. Good luck.
Jan 15, 2009 | RCA DRC8335
RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 13, 2008 | RCA DRC8335
RCA DRC8335: shows "padlock" symbol
Mark. Use the emergency factory-set master password 9688 to cancel and remove any previously owner set parental control password. Refer to page 26 of the User Manual if needed.
RCA DRC8335 User Manual (PDF 1.92mb) <---click here to begin immediate download
Please rename the ugly unreadable (encrypted filename) back to the original as highlighted above in blue, once the download has completed. mikeadams110@yahoo
Aug 15, 2008 | RCA DRC8335
RCA DRC8300N DVD Recorder/VCR Logo
794 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
