Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Mitsubishi WS-65313 Screen burn-in
I've a 5 yr old 65 in Mitsubishi WS-65313. It is starting to show the burn-in lines on the sides due to 4:3 (black bars). I'm not an expert. Is the burn-in on the screen itself (vs. lamps)? Is it the diamond-shield, screen-lenticular or the lens-freshnel the part that is burnt (i.e. the phosphorous) piece? Any points will be appreciated. If I buy the part is it ''simple enough'' to replace it myself? or is it better to have an expert do that work? Thanks in advance!!
ceo
  • atxceo Dec 13, 2009
    Thanks for the info. I am no expert on this, because of that I would have thought the phosphor was on the glass itself (the screen), but you are saying it is not the glass/screen itself but the tubes themselves? The screen itself (diamond-shield, screen-lenticular or the lens-freshnel) should all be OK? Thanks again.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
IF you have the area on either side of the picture used in the 4x3 burned---it is now burnt into the phosphor of all three picture tubes this set uses.
The real problem here is most of these sets the default setting for contrast or "picture" (same thing) is 100% and this is what burns fixed images into the tubes.
Pretty stupid, but that is how they are made--the black background in later models was replaced with a light gray one to try to prevent this.
If you do not have a warranty live with it--the cost of the three tubes would be about 900 dollars plus labor to replace them and adjust the set.
It takes less than 100 hours of use with the 4x3 up to cause this kind of problem, just like putting a fixed image on any projection set with full contrast and brightness set full--the damage is permanent.
I have replaced tubes in sets like this and when you get the tube out you can see the BURN in the phosphor.
I am sorry to give you bad news but based on your description this is what you have.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 13, 2009
Testimonial: "thanks for the feedback!"
  • HDKEV Jan 13, 2011
    To me, it is entirely egregious on Mitsu's end to make a set that default's settings to max by default or when the set is powered off and back on unbeknownst to the common user like myself. Too bad none of this was covered by the people who sold me the tv. I'm not a litigious person but spending $4k to now see permanent damage that could have EASILY been avoided is quite unfortunate. Mitsu shol dbe held responsible as I'm not the only one who's been adversely impacted by buying this mistake-of-a-set. P'od. KF
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Weight of T.V.
According to a quick Google search, it weighs 325lbs
Nov 16, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Is there any way to split the tv in two pieces for
I do not see any way to divide main wooden box of TV as you can remove front screen and back cover of TV but main cabinet of TV still remain the same.
Check below exploded views of WS-65313 for better explanation.
Thanks.
Oct 30, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
WS 65313 Mitsubishi went black all of a sudden
hold down the menu and input buttons after it shuts off it will flash with a code. call tv repair place and they can tell you what code means.
Jun 04, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 Blinking Screen
Does your system have hdmi input. If so hook up cable box, if it has hdmi, to the tv and see if that works.
If that clears up your problem you have a problem with the av board or boards.
I have found that most of the newer systems do not like the voltage and frequency from xboxes, playstations, or computers very well using the rca out and in.
Let me know what you find out. I might have a better solution for you.
Dec 18, 2008 | Mitsubishi WS-65313 65" Rear Projection...
My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Mar 05, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
475 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
